what do changing sprockets help?
Old Dec 10, 2000 | 12:53 AM
00Lakota300's Avatar
I have a 400ex and have been looking for upgrades. I have heard a lot of talk recently in the forum about changing sprockets. What do you get out of changing the size of the sprokets? Any explanation would be appreciated. Thanks
Old Dec 10, 2000 | 01:52 AM
Motorhead's Avatar
Ok, first off, I want to make this very clear: changing sprockets will NOT change your horsepower at all. Putting a smaller front sprocket on (like a 14t on a 400EX), all you're doing is moving the gears down about half a gear. 2nd gear is now in between where 1st and 2nd used to be, 3rd is between where 2nd and 3rd used to be, etc. Basically the greatest benefit is just being able to go slower in 1st gear (since it was a bit higher than I liked), and also getting a slighty stronger launch off the line.
Old Dec 10, 2000 | 01:54 AM
hot_shoe_cv's Avatar
Changing the rear or counter shaft sprocket or both will alter the gear ratio, hence the power band of the particular machine. To alter the band to get more low end, a smaller c/s sprocket is used or to get similar results, a larger rear sprocket may be used. For more top end performance at the expense of low end, a larger c/s sprocket can be used, or a smaller rear sprocket, or a combination of both is sometimes employed to achieve the desired result. It depends entirely on one's riding style & what part of the band he wishes to alter. In making these changes one must consider the change in the length of the chain that will occur to make sure of sufficient adjustment. Also one should check an older chain to determine whether it has stretched beyond accepted limits. A stretched chain is a worn out chain & will quickly ruin sprockets by causing hooking of the teeth.
Old Dec 10, 2000 | 01:58 PM
Thanks a lot for clearing that up. I think I am going to stick with stock.
cswiger
Polaris Side by Sides
12
Oct 5, 2015 03:34 PM
merryman
Sep 19, 2015 03:15 AM
Canamaniac!
Sep 15, 2015 06:19 PM
bigbear350quad
Sep 11, 2015 12:40 PM
Jason Campbell
Sep 7, 2015 02:25 PM
