Help with oil change
We where givin a kids quad and I need to change the oil.The brand is Himtco it is either a 90 or 110.The book that came with the quad has been soaked and I can not read it.I can find two drain plugs and only one fill spot that has a dip stick.If I fill the hole with the dip stick it will read full,But the oil sight window on the side shows no oil.
Thanks
Lug
Thanks
Lug
Thanks
Lug
Thanks
Lug
Thank you for your help.I was not sure if it had separate fill hole for the trans or not.It has a site window that was showing no oil but the dip stick was reading full.All It needed was a little more engine oil to make it show up in the window.
