Help with oil change
Old Nov 19, 2006 | 11:40 AM
onelugnut's Avatar
Default Help with oil change
We where givin a kids quad and I need to change the oil.The brand is Himtco it is either a 90 or 110.The book that came with the quad has been soaked and I can not read it.I can find two drain plugs and only one fill spot that has a dip stick.If I fill the hole with the dip stick it will read full,But the oil sight window on the side shows no oil.
Thanks
Lug
Old Nov 19, 2006 | 07:58 PM
MIDDLEAGEDCRAZY's Avatar
Thanks
Lug
I am not familiar with that brand. However I beleive what you are talking about is that the one with the dipstick is the oil. the other should be gear lube. In which there should be A plug that you can see how high the lube is.
Old Nov 20, 2006 | 12:51 AM
onelugnut's Avatar
Thank you for your help.I was not sure if it had separate fill hole for the trans or not.It has a site window that was showing no oil but the dip stick was reading full.All It needed was a little more engine oil to make it show up in the window.
ultangler
Nov 30, 2024 01:35 AM
ReconBayou
Oct 31, 2022 05:37 PM
Jackg17
Ask the Editor
Jul 16, 2018 04:01 AM
Gwolf228
Feb 18, 2017 01:36 AM
Jackg17
Sep 26, 2015 09:30 PM
