Can't Start SunL 50cc
Old Nov 21, 2006 | 03:42 PM
ScooterDad's Avatar
Default Can't Start SunL 50cc
Can anyone give me some pointers on how to start this ATV? I have had it about a year and it ran good this past Spring. It has not been ridden all summer and now that the weather is getting nice in TX I can't seem to get it started now. I've checked for spark and am getting a good solid one. I also have the smell of fuel on the spark plug (and have cleaned it frequently) so I believe my fuel supply is okay. The gap has been checked and is okay. The poorly written (broken English) users manual tells you to pull the choke out all the way when the engine is cold. I have tried starting with full choke, half choke, no choke and nothing..it just keeps cranking (I have had to repeatedly charge the battery and I'm afraid of ruining it). I've tried "giving her some juice" while it's cranking but that just seems to flood it. Since I'm getting spark, I'm thinking it is not my cuttoff switch circuitry. I thought I read on a separate post that someone suggested slowly pulling out the choke while it is cranking. I've tried that and it won't even sputter!
Any suggestions would be greatly appreciated.
Thanks.
Old Nov 21, 2006 | 09:52 PM
1976's Avatar
A. Change Gas
B. Change Plug
C. Charge Battery 100%
Old Nov 21, 2006 | 11:42 PM
2manytoys's Avatar
Sounds like it sat for a while. The gas may be bad. Try spraying starting fluid into the intake to see if it fires. If not then its notm a fuel problem. The valves may need to be adjusted.
Old Nov 22, 2006 | 11:22 AM
ScooterDad's Avatar
Thank you. I recently put new gas in it so the fuel should be okay. I will try starter fluid. With this new of an ATV, it wouldn't be that the carb needs to be cleaned already, would it? Hopefully the starter fluid will work.
Old Nov 23, 2006 | 02:46 PM
Hula's Avatar
I'm having the same problem with my 100CC Chinese Maxfine quad. When my buddy squirts carb cleaner into
the carb it will fire up but then dies when he stops. You should try that. Regarding the carb needing cleaning
already, even though it's a new quad, unfortunately you may need to that. Please let me know if you get it going
as I'll attempt whatever may work
Old Nov 26, 2006 | 07:04 PM
ScooterDad's Avatar
I finally got it started..thanks to a combination of starter fluid and carb cleaner. Once it began to run, a lot of white smoke out the back so I'm assuming the cause was a combination of a dirty carb and sitting too long without being started. Thanks for all of your help.
Old Nov 26, 2006 | 10:38 PM
2manytoys's Avatar
Damn im good. LOL!
Old Nov 27, 2006 | 11:28 AM
ScooterDad's Avatar
I'm just glad it wasn't the valves needing adjusting.
Thanks again for the suggestions.
Old Nov 28, 2006 | 02:10 AM
Hula's Avatar
Hi 2manytoys, any suggestions for my Maxfine 100. It runs great as long as your squirting carb cleaner into the
intake but dies as soon as you stop.
Old Nov 28, 2006 | 12:01 PM
ScooterDad's Avatar
By the way, "too many toys" - nice toys! I looked at your picture page and you have some nice ATVs along with what looks like some nice land to ride on. You're about 40 or so miles away from my brother who lives in West Chester.
