Can't Start SunL 50cc
Old Nov 28, 2006 | 04:36 PM
2or4wheels's Avatar
Default Can't Start SunL 50cc
any suggestions for my Maxfine 100. It runs great as long as your squirting carb cleaner into the
intake but dies as soon as you stop.
Well, if it runs on starting fluid, then you have one or more of the following:
Clogged fuel filter - remove and replace
Clogged petcock- drop tank and empty, then remove and clean petcock
stuck float needle and seat
clogged pilot jet
clogged main jet-Remove carb., carefully disassemble, clean every oriface(hole) you can find, clean them all again just to be sure, carefully reassemble, then replace and reconnect, you should need to make some minor adjustments, but then you are on your way.
-d3
Old Nov 29, 2006 | 12:37 AM
2manytoys's Avatar
HULA,
Like 2or4 said it sounds like a carb problem or clogged fuel tank, fuel line. These quads get alot of debris from the tank and all it takes is 1 peice to clog a jet. Take the carb apart and clean all teh jets, empty tank, clean lines, put fresh fuel.
Scooter,
Thanks! I work in West Chester but live in Lancaster. We do have some land to ride local but only about 1.5-2 hrs away to ride on thousands of acres.
Bigredjeep
Apr 10, 2020 02:55 AM
merryman
Jun 27, 2015 03:31 AM
sticky123
1) Engine problems..
Jun 14, 2015 07:36 AM
1000gade
May 27, 2015 12:37 PM
dcoleman
Oct 5, 1999 01:34 AM
