Fuel shut-off question
Old Nov 22, 2006 | 03:10 AM
speedknot's Avatar
Default Fuel shut-off question
This may be a dumb question but how do you read the positions of the fuel shut-off switch? Is up "on" and down "off"? The manual says nothing about it.
Also, my sons Hensim 50cc atv seems to stall out when he comes to a stop but is able to start right up after that and keep going. Can anyone advise if this is a simple carb adjustment or something else? Thanks.
Old Nov 22, 2006 | 09:36 PM
2manytoys's Avatar
As for the fuel shutoff that may be tricky but all you have to do is disconnect the line after the valve and turn the valve. This will be the best way to see. For the hensim it sounds like the air screw needs adjustment and the idle. What you need to do it start the quad and let it warm up. Then turn the air screw out till you hear the idle increase. Keep turning till no change in idle then back in about 1/8 turn. Then you can lower the idle till the quad does not creep anymore.
Kyle5050
Dec 13, 2019 04:25 AM
mtdewmn
Jan 19, 2017 12:13 PM
Aitch
Jul 21, 2015 09:40 PM
Ask the Editor
12
Jul 21, 2015 06:57 AM
Mikea1978
Jul 4, 2015 12:37 PM
