ds 650 mods
Old Nov 22, 2006 | 04:32 PM
midlifecrisis's Avatar
Default ds 650 mods
Ok.... I'm not an idiot when it comes to mech. stuff.But first offl Is 05 ds 650x fuel injected... I dont think so...but confused...
Second. What minor mods. do you guys recomment.. Under $1500.... Dont want to change engine internals, at least no until it blows up....lol....
What gains would I expect from these Mods.
I believe from searching, the stock hp rateing is around 44
thanks mike,,,,,,
Old Nov 22, 2006 | 04:58 PM
nathanpri08's Avatar
Default ds 650 mods
To answer your question No.And some good mods are a k&n witch you already got,end cap or a (HMF) slip-on.You could do alot for 1500.Carbs and stuff like that.But a port job even though you dont want to mess with internals.I f you ride trails drop a tooth on your front sprocket.To make it easy you could do a search for ds mods.You should get mile long pages on the subject.
Old Nov 22, 2006 | 05:22 PM
Default ds 650 mods
What type of slip on would you guys recommend... do I have to rejet the carb with that...also, what kind of carb mods .....
Who does port work in the michigan area....I'm abour 1hr from detroit in Canada....
thanks
Old Nov 22, 2006 | 05:32 PM
DubaiPolaris's Avatar
916 Reaper - Pure Evil Inside!
Default ds 650 mods
I just did a 46HV Lectron, ported intake, endcap, TwinAir PowerFlow, and clutch on my 04-X for just over a grand and very happy with the improvement and results from this. Awesome gains!
Yes, you will have to rejet for a new exhaust. For stock carb mods look
here.
Chris
Old Nov 22, 2006 | 06:01 PM
duneittilludie's Avatar
Default ds 650 mods
The mods that DubaiPolaris suggested are a very good way to go.Along with those mods i would suggest going to a 520 chain conversion and aluminum sprocket for another good gain.You may also want to consider getting a CDI with a higher rev limit to take full advantage of your mods.
Customer Service #1
May 15, 2020 08:46 AM
Sep 23, 2015 06:23 AM
PrairieDog126
Sep 16, 2015 01:33 PM
1ArmBandit
Sep 8, 2015 08:59 PM
JakeXBL
Sep 5, 2015 01:08 PM
