axle nuts won't stay tight
Old Nov 25, 2006 | 06:26 PM
Speedy2222's Avatar
Is A Power Sport Junkie!
Default axle nuts won't stay tight
well i can not for the life of me figure out a way to keep the damn axle nuts from staying tight.. they will back off to hand loose but no more
Old Nov 25, 2006 | 06:40 PM
yamahalltheway's Avatar
THREAD LOCKER!!!! and just wondering but not sure are there cotter pins that go in front of nut to keep it from falling off???
Old Nov 25, 2006 | 07:49 PM
Speedy2222's Avatar
axle nut not spindle nut
and i use blue lock tite
Old Nov 25, 2006 | 07:59 PM
o well cant help you there
Old Nov 25, 2006 | 09:11 PM
bombrider04's Avatar
the axle nut that tightens down the rear carrier and bearing correct...there should be a ring that pushes up against the axle once you have it tight and once the axle nut is tight the ring should be right up against the groove on the axle from keeping it from coming loose
Old Nov 26, 2006 | 02:02 AM
Scooter86's Avatar
Knows Old ATV Questions!
It doesn't look pretty, but if you ever get in a bind on the trail, use duct tape and wind it the opposite direction the axle normally turns. That can at least get you home if one loosens up again.
Old Nov 26, 2006 | 11:02 AM
recon99's Avatar
Speedy, what are you using to tighten them down? You need something tough with a good bit of leverage, I use a 24" adjustable wrench I got at harbor freight and it doesn't come loose until i want it to, and then it's a struggle usually. If you are getting a good bit of leverage on it, try tightening them down as good as you can get them, then wrapping them tightly with some electrical tape to make it impossible for them to vibrate loose.
Old Nov 26, 2006 | 11:28 AM
Speedy2222's Avatar
idk if they are vibrating loose... or if it's soemthing else...
they have always been fine... never had a problem with em..
Old Nov 26, 2006 | 10:28 PM
2FAST4URASS's Avatar
RAP sum teflon tape around the threads make it so the nut is a lil hard to get on ive done this before on my old tri-z 250 it worked IF.. that doesnt work clean up around the nut and axle and put a lil jbweld on the side of the nut once you have it tight and in place when the time comes to remove the nut just chip the jb weld off with a screw driver..sounds stupid but it works.....
Johnny Mac
Aug 15, 2019 03:13 PM
Roro
Ask the Editor
Sep 30, 2015 10:58 AM
r1pilot83
Sep 27, 2015 07:38 PM
2many2ride
Sep 27, 2015 04:35 AM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
