Eton 90 CDI Box Location
This has probably already been coverd but I am unadble to find the answer.
I have a 2005 Eton 90. Where is the CDI box located? and does it have the one that has the adjuster on it?
Any help would be greatful.
Thank you,
Pineaple
Thank you,
Pineaple
I suppose it's possible that it's in a different location. On my '05 the cdi is about the size of a credit card and 1/2"to 5/8" thick. It's "jammed" tightly down by the battery on the right side. It's black like the battery so it's not hard to miss. It can be hard to spot if you don't know exactly where to look. Are you having problems or just need to adjust the cdi? I've recently had a battle with my own but it's doing okay at the moment.
I have a viper 90R, if you have a another model the cdi may be located somewhere else. Look under the plastic, find the wiring harness, follow it. It must go to the cdi. Good luck.
It is under the front grill below the night rider looking light on the steering column. Here is a link if your are interested at the proposed speed gains.
Eton Viper 90 CDI and tech link
I did not notice too much difference on my daughters quad. My other daughter has an 04 viper and I needed to loop a green wire to bypass the cdi but yours should have a dial.
Good Luck
Good Luck
