Eton 90 CDI Box Location
Old Nov 27, 2006 | 01:20 AM
Pineaple's Avatar
Default Eton 90 CDI Box Location
This has probably already been coverd but I am unadble to find the answer.
I have a 2005 Eton 90. Where is the CDI box located? and does it have the one that has the adjuster on it?
Any help would be greatful.
Thank you,
Pineaple
Old Nov 27, 2006 | 04:34 PM
steviedummy's Avatar
It's located under the seat, right of the battery. It should have an adjustment, 1-4.(just replaced the on my son's '05)
Old Nov 27, 2006 | 06:20 PM
Pineaple's Avatar
When I look under the seat all there is is the battery and no CDI box. Do I have to remove any of the plastics to get to it?
Thank you,
Pineaple
Old Nov 27, 2006 | 06:45 PM
I suppose it's possible that it's in a different location. On my '05 the cdi is about the size of a credit card and 1/2"to 5/8" thick. It's "jammed" tightly down by the battery on the right side. It's black like the battery so it's not hard to miss. It can be hard to spot if you don't know exactly where to look. Are you having problems or just need to adjust the cdi? I've recently had a battle with my own but it's doing okay at the moment.
Old Nov 27, 2006 | 06:54 PM
Pineaple's Avatar
I just want to adjust it. I may have just missed it when I looked last night. I will look again.
Thank you,
Pineaple
Old Nov 27, 2006 | 09:55 PM
Pineaple's Avatar
I just looked and there is nothing next to the battery. It is an 05 90 eton, so I am wondeing where the cdi can be?
Old Nov 28, 2006 | 08:46 AM
I have a viper 90R, if you have a another model the cdi may be located somewhere else. Look under the plastic, find the wiring harness, follow it. It must go to the cdi. Good luck.
Old Nov 28, 2006 | 12:29 PM
Pineaple's Avatar
Mine is just a 90 not a 90r. So I will look under the plastics for it.
Thank you for your help.
Pineaple
Old Nov 29, 2006 | 05:03 PM
GMoney69's Avatar
It is under the front grill below the night rider looking light on the steering column. Here is a link if your are interested at the proposed speed gains.
Eton Viper 90 CDI and tech link
I did not notice too much difference on my daughters quad. My other daughter has an 04 viper and I needed to loop a green wire to bypass the cdi but yours should have a dial.
Good Luck
Old Nov 29, 2006 | 05:17 PM
Pineaple's Avatar
GMoney69,
Thank you. Is there any other inexpensive way to get a little more power?
Thank you very much.
Pineaple
