2004 Yamaha Bruin won't shift?
Old Nov 28, 2006 | 12:52 AM
apowder97's Avatar
Default 2004 Yamaha Bruin won't shift?
This last saturday I was out riding and was going thru a small creek. The water was about halfwas up my engine. I got high centered on a root that was under the water and had to be pulled out. ATV continued running fine the entire time. After I got the bike unhooked and all I began my trip home. Noticed then that the bike wasn't shifting. I put the shifter in F and it acts normal and all. Once I start to accelerate the bike seems to not shift out of what I guess would be first gear. It just revs out. Any clues as to what might be the reasoning behind these shifting issues.
Old Nov 28, 2006 | 08:15 PM
hondagrizzly's Avatar
From what i am hearing i think that water is in your belt drive causing the belt to slip off track. if so, u will need to remove the belt case or if it has a drain plug at the bottom.
Old Nov 28, 2006 | 09:32 PM
apowder97's Avatar
I've pulled the entire housing off the belt drive. Everything in there was completely dry. Thanks again.
Old Nov 28, 2006 | 09:35 PM
Is it still acting up since you did that
Old Nov 28, 2006 | 09:43 PM
apowder97's Avatar
Yeah it's still doing the exact same thing. It goes but just wants to rev out, doesn't seem to shift out of first or whatever you would call it.
Old Nov 28, 2006 | 09:48 PM
well now im stumped. GOOD luck
Old Nov 29, 2006 | 12:04 AM
yamahalltheway's Avatar
how bad of shape is the belt?? you might have burned it up if the belt is in good shape well i would pay a vist to the dealer
Old Nov 29, 2006 | 12:23 AM
apowder97's Avatar
Yeah i'm gonna run it down to my buddies dads shop this Saturday. He's works on atv's and lawnmowers. We've trusted him with all our stuff before. If he doesn't know i'm gonna take that dreaded trip to the yamaha shop.
Old Dec 29, 2006 | 02:54 PM
apowder97's Avatar
Well i got it fixed. The rollers in in the so called "transmission" were packed with dirt. Runs like a champ now. Ran so well I went and traded it in on a new 05 Arctic Cat 660. Thanks for the help.
Ean
Dec 19, 2022 08:48 AM
mbkirk
Technical and How-To Articles
Aug 14, 2015 08:12 PM
Stirling
Aug 11, 2015 07:23 AM
blessedn09
Aug 9, 2015 03:07 AM
papahouse
Jul 28, 2015 12:42 PM
