LT500 cooling probs
Old Sep 5, 1999 | 09:41 PM
roostmonkey's Avatar
I have a 89 500 Quadracer that has a cooling problem. While running the cylinder gets hot but the hoses and radiator don't.
While running I pulled off the return hose(head to top of radiator) and water was just dribbling out.
I ran water through the system via a garden hose and the water was coming out good.
I pulled off the side case and inspected the waterpump. The impeller looked perfect and doesn't spin w/o the motor turning over.
So what do you guys think is the problem?...air in the system and the impeller is cavitating?..any ideas on a fix?...Could it be the radiator cap?
The bike has seized before because of this problem and it is getting expensive to fix.
Thanks
Brian
By the way, I love this new UBB
[This message has been edited by roostmonkey (edited 09-06-1999).]
Old Sep 16, 1999 | 03:58 AM
jerrygomez's Avatar
try 60% distilled water/ 40% hi quality anti freeze. Run atleast .003" clearance and stay away from Wiseco when running such a big piston. Also run engine, take radiator cap off and see if water circulates. It might still be water pump not turning somehow.
Old Sep 16, 1999 | 04:04 AM
HERBERT C.'s Avatar
Jerry, What is wrong with wiseco over bore pistons? I have a 89LT500 and I am running a .100 over wiseco in it. Can u give any info? It would be appreciated......Herbert
http://community.webv.net/murdo77/QuadzillaZone
Herbert~~99Wolverine & 89LT520
IMLN
Sep 28, 2015 03:32 PM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
BigCam
Sep 16, 2015 01:53 AM
alzgarvin
Sep 11, 2015 08:53 AM
lancemll88
Sep 5, 2015 03:16 AM
