2005 sports 700efi 4x4 not working... Help please!
Old Dec 1, 2006 | 04:19 PM
mudcat34's Avatar
Default 2005 sports 700efi 4x4 not working... Help please!
Hey guys I have a buddy's sportsman 700 EFI sitting in my guage right now cause the 4x4 quit working. I first thought fuse but have seen polaris uses the relay type fuse and I could feel it click when ever I tried to turn the switch on so i put a plan ol 7 amp fuse in and it worked for a few minutes or so but quit and I pulled the fuse and it wasnt blown so now what?[img]i/expressions/face-icon-small-confused.gif[/img]
Old Dec 1, 2006 | 06:50 PM
PGTDriver's Avatar
Is the AWD symbol under the switch lighting up? If it is then I would say your good there. Then check/change the front hub fluid. Its a pretty basic system and not realy all that complicated in my opinion. Are the front drive shafts spinning? When i baught my scrambler the 4x4 didnt work because of a crack in the tranny and the fron shafts didnt spin at all when in 2wd.
Old Dec 1, 2006 | 06:59 PM
Instigater's Avatar
This is a newer style than yours, it doesn't have the "big" hubs. In 2wd, the older axles spin according to the drive train speed and newer ones spin by ground speed!
Old Dec 1, 2006 | 07:25 PM
rubberknob's Avatar
I bet something fell apart in the front differential ( i think some plastic part broke). After this happened it would engage from time to time but was completely unreliable. This happend to me last winter thankgod it was under warranty.
Old Dec 1, 2006 | 07:36 PM
x_scrambler3's Avatar
I would check the wires an see if there bear anywhere that it is shorting out. that would be what to start with.
Old Dec 4, 2006 | 10:45 AM
mudcat34's Avatar
Thanks for the help guys! I took it out yesterday after trying a little bit of everything yall had said and changed the fuse again just cause and it is working now its not working right but it is working now it just isn't wanting to come out of AWD even when I switch it back to 2wd the front wheels still kick in if my rear tires spin. Rather have that than no 4wd [img]i/expressions/face-icon-small-smile.gif[/img]
Old Dec 4, 2006 | 03:55 PM
rubberknob's Avatar
I think your front diff got magnitized (making it engage). You could try changing the fluid it may help. I don't really understand the whole "magnitized" thing maybe someone else does.
salixair
Nov 3, 2015 08:25 AM
Sep 30, 2015 01:37 AM
cboler9
Sep 24, 2015 08:35 PM
kampswas
Sep 23, 2015 05:05 AM
Brandon400
Sep 5, 2015 08:44 PM
