02 sportsman dead
Old Dec 2, 2006 | 09:47 PM
scrammersam's Avatar
Default 02 sportsman dead
friend has a 2002 sportsman 500 ho and riding it the other day it shorted out. To activate the winch there is a toggle switch by the speedometer (dealer installed) and it was on and he does not think it should of been.The lights went out and every switch quit working and when he shut it off it would not start again. any ideas? im stumped
Old Dec 3, 2006 | 12:04 AM
duffus's Avatar
can it be pull-started?
if it does start via pull start, does the dash or any light come on?
If not, a relay may have been tripped-- lemme know, but def turn off the winch switch (or disconnect it all together to check the rest of the system)
Old Dec 3, 2006 | 12:40 AM
the quad is completely dead, no lights or anything. he has replaced all 3 of those fuses, is there a diff. between those and a relay? if so wheres the relays located?
Old Dec 3, 2006 | 12:51 AM
duffus's Avatar
if it can't be pull started, we might have a more serious issue going on-- i assume it cannot be pull started ?
the relays-- if i remember right, there is one under the front "hoood" and one in the back near the starter solenoid. Both are sealed in a black plastic "boot."
Check the battery voltage also-- if a cell collapsed in it, then that will give the same symptoms. If the voltage is <9v, try charging or replace it first.
Old Dec 3, 2006 | 12:59 AM
yea if we are talking about the same thing, the black "boot", thats those plastic bag type things right? he found 3 of them and replaced them all
Old Dec 3, 2006 | 01:13 AM
duffus's Avatar
hmm... yeah those relays are what stopped all my electrical components on my 02--- My next step would be to check the keyswitch-- use a multimeter or test light and trace the power from the solenoid, into the switch, and out of the switch. It is possible the switch is not transmitting a signal that indicates teh "on" position.
Just as a random comment: -- did u check the "kill" switch on the left thumb control? I've drove myself nuts trying to start a machine when i accidentally switched it to off.
i hope something here helps-- i'm still thinking on it tho.
slowgsxr97
Mar 18, 2022 03:40 AM
cody500ho
14
Aug 14, 2015 05:03 PM
Hondamx751
Aug 13, 2015 01:06 AM
Hankey Pankey
Jul 31, 2015 05:50 PM
Hankey Pankey
Technical and How-To Articles
Jul 29, 2015 10:57 PM
