Predator Air Filter Kits, Which one???
Old Dec 5, 2006 | 12:12 PM
HobieSun's Avatar
Default Predator Air Filter Kits, Which one???
Hello, I have an 04 predator 500 and am looking for a power kit for it. Please let me know what most people are running and what it all comes with. Are there any air box eliminator kits out there? I can't stand messing with the stock set up everytime I check the filter. Any information is welcome. Thanks.
Old Dec 5, 2006 | 07:41 PM
lostdownunder's Avatar
I/m using the K&N filter SN-2550 & K&N filter wrap SN-2550PK.
Fits straight on to the carb inlet & does away with the filter box.
I left the box in place though as it makes a great tool box once you block up the holes in it.
Old Dec 6, 2006 | 01:43 AM
HobieSun's Avatar
That is awesome. How are the jets set up? Stock pipe still.
Old Dec 6, 2006 | 02:15 AM
Haven't changed the jetting yet. Still on the standard 150 main.
Can feel the change with just the new filter.
I have a stage 3 Dynojet kit on hand to use when I put the pipe & header on. I have ordered a pro circuit system.
Old Apr 2, 2007 | 12:59 AM
DjSeabass's Avatar
hey when u remove the aibox whats tht little tube in the right connected to the egine and if i remove the aibox do i just leave it setting there or do i have to put somthing on it
Old Apr 2, 2007 | 02:40 AM
That's the crank case breather. You need to put a filter into that as well. Any small filter that fits a 1/2"hose will do. I think a crank case breather filter off a mini is what I used.
Put on a pro circuit system & played with the jetting. Stayed on the stock pilot jet & ended up with a 170 dynajet in the main. Mixture set at 2 1/4 turns out.
fordfaithful21
Dec 7, 2015 05:52 PM
Brandon400
Sep 7, 2015 12:20 PM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
1966F100
Jul 14, 2015 12:19 PM
1966F100
Jul 12, 2015 03:08 AM
