scrambler 500 won't start after sitting for months outside
Old Dec 9, 2006 | 08:30 AM
Don4949's Avatar
Default scrambler 500 won't start after sitting for months outside
Hi guys,
I've got a 2001 Scrambler 500 4x4 & injured my shoulder & haven't ridden it since last January. It has been sitting out since then, in all kinds of weather & now won't start unless I spray starting fluid in it & quits as soon as the spray is used up. Any ideas? Thanks, Don
Old Dec 9, 2006 | 09:28 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
could be the fuel pump isnt working, could be the carb needs to be pulled off and cleaned from the gas that varnish up in it. i would start w/ the carb and drain the old gas out and put fresh in. make sure the shut off is working and not pugged up. is the plug wet from gas is it getting any to the plug?
Old Dec 28, 2006 | 12:48 AM
STARKSREBEL's Avatar
clean the tank and carb.the gas went bad and has turned to varnish.make sure when you clean the carb not to get any cleaner on the rubber parts or they will exspand and be useless.
Old Dec 28, 2006 | 07:30 AM
Bing's Avatar
Super Quad Patrol
Smokes meat all the time!
drain the fuel and get new gas
clean the bowl and jets on the carb (pilot and main) (actually remove,,,and make sure they are not obstructed)
Old Dec 28, 2006 | 06:22 PM
BGRDTRUK's Avatar
Don't forget to change the oil also.....that much setting and it'll have a good bit of water in it.
Old Dec 28, 2006 | 07:22 PM
scrammersam's Avatar
id do a whole service on it
Old Dec 28, 2006 | 07:31 PM
Pennyless's Avatar
I have the same quad and if it sets for more than a month I have to prime the fuel pump to get it to start and run. You may have some of the other problems listed but I would try the fuel pump first.
MikeyBoyesq
Nov 27, 2020 02:44 PM
TegraQuad
1) Engine problems..
13
Nov 26, 2017 01:40 PM
Rigit
Sep 29, 2015 03:02 AM
1000gade
May 27, 2015 12:37 PM
firebrat
Apr 30, 2001 09:26 AM
