DS650 engine/F650 compatibility, what years, fuel injection?
Old Dec 10, 2006 | 11:21 PM
baja02's Avatar
Default DS650 engine/F650 compatibility, what years, fuel injection?
I own a 2002 Bombardier DS650 Baja(modle # 7484)
I know where there are two BMW f650's that are for sale with salvage titles. I know for a fact one is a 01' F650 Fuel Injected, not quite sure what the story is on the other.
Were there F650's made without fuel injection?
Would a DS Head fit on a F650 bottom end if not?
Would a F650 Engine bolt right into a DS frame, same mounts?
I was told that the BMW F650 engine comes with about 20 more HP, than a DS engine. If you install a Ron Woods Stage 2 Kit you would have the same engine.
DS650+RWStage2=F650 Stock set up---- same deal
Old Dec 10, 2006 | 11:53 PM
DuneMe's Avatar
The tranny isn't geared the same. . . probably a wider ratio.
Don't know about the bolt-up of the rest. I think the FI depends on the bike more than the year but, not sure.
I think this is more than you'ld want to bite-off. IMO
Old Dec 11, 2006 | 12:18 AM
DSNUT's Avatar
A couple of things to consider:
The F650 has a single exhaust port as I recall. So you wouldn't really want to use the BMW head because of the need for a custom exhaust.
I would want to know if the intake ports were different to. I use a BMW intake with my dual carbs but that is off a carburated F650. I don't know what the intake ports are like on the EFI model years. This would tell you if you can use the streetbike fuel injection on the DS head. There is no way to know if the fuel injection will be dialed in with a DS exhaust. You might be rich or lean so you would have to check this out and do what it takes to solve it, i.e. power commander or exhaust and intake mods.
You may have to go to some lengths to protect the streetbike components, EFI, Computer, Wiring harness from the abuse and elements it will see on an ATV. Most street bikes are not setup for off-road. The F650 is somewhat so it may not be a problem.....check it out.
The F650 tranny is a closer ratio as I recall. I am remembering back to the Yjacket days and my memory is a little hazy but I think that is right. The problem is, I don't know for sure if the tranny can handle the load put on it by an ATV reliably. It might but they changed the tranny for the ATV for some reason. I believe the F650 tranny if back-cut, could be a good racing tranny. One of the things that hurts the DS is how wide ratio the gears are compared to other ATV's.
That is all I can think of right now. What would you gain for all the research and trouble? Rhetorical question that the guy spending the time and money has to answer......[img]i/expressions/face-icon-small-wink.gif[/img][img]i/expressions/face-icon-small-smile.gif[/img]
Good luck
Old Dec 11, 2006 | 12:22 AM
ERBEDS650's Avatar
Heads are different, intake and exhaust , I looked.
still would like to look into the fuel Injection system and adapt to a DS.
Text http://faq.f650.com/FAQs/F650HistoryDifferences.htm
Old Dec 11, 2006 | 10:44 AM
02BAJA89ZILLA's Avatar
I didnt want to use the FI, i want to use a ds head and bolt it on a bmw bottom end. so you dont need custom pipes, if bmw not fuel injected, use exsisting carbs
Old Dec 11, 2006 | 12:16 PM
DSNUT's Avatar
What if the F650 pipe is designed for a single exhaust port and the DS head comes with dual exhaust ports? [img]i/expressions/face-icon-small-smile.gif[/img]
Old Dec 11, 2006 | 12:32 PM
rcoop's Avatar
Can the single exhaust port head be ported to outperform the dual port head ?
Old Dec 11, 2006 | 02:21 PM
DSNUT's Avatar
Oh, I see. You are wanting to know if you can use an F650 bottom end with a DS650 head in a DS650 ATV. Is that right?
It is the tranny that needs to be looked at and determined if it is sufficient.
Old Dec 11, 2006 | 11:19 PM
baja02's Avatar
Ya boys thats what im thinking, using the ds head on the bmw bottom end, in a ds frame. Then i could use the ds exhaust. would this work?
Old Dec 11, 2006 | 11:24 PM
baja02's Avatar
after using the bmw bottom and the ds top, through in a ron woods stage 2 kit on the top then you would have a f650, Right? In a ds frame. I might call ron woods and see what they got to say, that would be a 20+ HP DS with longer gears. If I can buy these bikes cheap enough could build a monster
