Kazuma 90cc tail light
Old Dec 12, 2006 | 03:31 AM
CathastrophiX's Avatar
Default Kazuma 90cc tail light
Has anyone mounted a tail light to a Kazuma 90cc Falcon?
What type are the headlight bulbs (watts)?
Can you mount a tail light without burning the electrical system?
Old Dec 13, 2006 | 10:29 AM
2manytoys's Avatar
You wont be able to find a tail light that will draw too much power because they are low wattage unlike the headlites. You could also get an LED tail light that will draw even less power but will also be much brighter. Call John at Raceway and get a tail light from him. Then all you have to do is wire it up to the key switch.
Old Dec 13, 2006 | 01:53 PM
Do you know how many watts the headlight bulbs are?
When i rev the Kazuma they get brighter, otherwise they are really dim.
I?m from Sweden so i think i better buy a taillight from someone closer....
Old Dec 13, 2006 | 11:12 PM
2manytoys's Avatar
The Kazuma works off of a capacitive discharge system. Thats why they get brighter when you rev the bike. If you turn the bike off the lights should not work. The bulbs should be either 15 or 20 watt bulbs. If you go led tail lights then you should have about 3 watts.
Old Dec 14, 2006 | 10:40 AM
BigReub's Avatar
I picked an LED marker light and installed it on the rear fender. Connected it to the key switch, parrallel with the headlight. This is on a KAzuma 50, but should be roughly the same.
Old Dec 18, 2006 | 12:25 PM
Mounted a small taillight (5watt bulb) under the battery, looks nice!
Old Feb 14, 2007 | 08:27 PM
mikesg's Avatar
GO with the LED if you can!!!
panicmanic
Sep 28, 2015 12:59 PM
MooseHenden
Family ATVing Photos
Sep 20, 2015 04:14 PM
MrTrashMan2U
Sep 9, 2015 11:44 AM
MrTrashMan2U
1) Engine problems..
Sep 9, 2015 11:11 AM
Tim Shoe
Sep 7, 2015 12:15 PM
