Jetting on a 450R
Old Dec 12, 2006 | 11:12 AM
budmantom's Avatar
Default Jetting on a 450R
I live at an elevation of 4500ft and it's my understanding that my 05 450R is jetted to sea level (just like every other bike), so I should be running rich(?).
I just added a UNI air filter and a HMF QRS full exhaust and the bike runs great, so should I get it re-jetted?
Thanks for your help,
Tom
Old Dec 12, 2006 | 10:31 PM
budmantom's Avatar
ttt
Old Dec 12, 2006 | 10:52 PM
bombrider04's Avatar
Yea I would rejet as Honda does jet it lean from the factory and your bike will be running lean, and you don't want to be messing up the engine, so I would rejet. I am not sure what size jets though as I haven't messed with my carb just yet and don't have any performance mods that would make me need to rejet, so someone else on here can chime in on that topic.
Old Dec 12, 2006 | 11:12 PM
budmantom's Avatar
In stock trim wouldn't I be running rich at a higher elevation as opposed to someone in New Jersey?
Old Dec 13, 2006 | 06:13 PM
you can try it but you are lean from the factory and will be lean from putting on an exhaust and airfilter.
Old Dec 17, 2006 | 04:35 PM
bulldogfallon's Avatar
A 180-185 Main jet would be in the ballpark if you have you airbox lid off
That is what I have seen many post on other forums....
Elevation makes you run richer as far as I know
Old Dec 17, 2006 | 04:49 PM
budmantom's Avatar
I have the air box on, do you know what is stock?
Tom
Old Dec 17, 2006 | 06:47 PM
Tom
I don't know what the jetting would be with the lid on....Most run with the lid off or at least 1/2 of the top cut out
Check out *Edited by ATV Connection Moderator*
It is a great place for info for your quad
Old Dec 18, 2006 | 02:50 AM
chenoweth122's Avatar
my stock is a 120, i live at 3000 feet and it runs a little rich. but if you are that hi than i would say to rejet. but the first thing to do it look at youre spark plug, don't do what everybody else does, go off the color of youre spark plug and jet accourdingly. good luck
ReconBayou
Oct 31, 2022 05:37 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
XxS0ccerstarxX
Sep 8, 2015 12:02 AM
