Honda Rancher Axel Bearings install.
Old Dec 16, 2006 | 04:52 PM
RABDAB's Avatar
Default Honda Rancher Axel Bearings install.
If any one has the book or page about install. please help me out. can email or fax. teh quad is in our garage tourn apart because i left the book at work.
Anyhelp would be a apprictiae.
Ryan
rbflurry01@hotmail.com
Old Dec 16, 2006 | 09:21 PM
mykool61679's Avatar
everything should just slide off.
Old Dec 17, 2006 | 01:44 PM
cluby's Avatar
Which wheel bearing are you tring to change, front, or rear which side?
Old Dec 18, 2006 | 09:00 AM
RABDAB's Avatar
I got the rear done, now I need to do the front bearings both sides. Dose any one have any info they could send me ?
Old Dec 18, 2006 | 01:02 PM
cluby's Avatar
Here's how I do the fronts.
remove wheel, removed brake drum, unbolt (4) brake panel, take off lower nut on knuckle, use a prybar between the a arm and knuckle be careful not to tare the ball joint seal, push down and use a hammer and hit the a arm where the ball joint goes through.
Once you have the a arm free unbolt the lower shock and lift up the a arm to get the axle out, take off the upper ball joint nut, install the bolt for the lower shock mount, take your hammer and hit the knuckle just above the bearings where it at a angle, the knuckle should be removed now.
Take out the seals find the snap ring and remove baerings.
Ean
Dec 19, 2022 08:48 AM
Kodiak-vic
Jul 29, 2015 03:06 AM
Chuck188
Jul 17, 2015 02:45 PM
Scottma518
Jul 16, 2015 09:19 PM
Scottma518
Jul 10, 2015 12:42 AM
