04 700 Sport waterpump seal replace advise
Old Dec 18, 2006 | 06:13 PM
trooperK's Avatar
Default 04 700 Sport waterpump seal replace advise
There is a very small amount of coolant coming from the weep hole on my 04 700 Sportsman. I assume it is the water pump shaft seal in the gear/stater housing that needs to be replaced. My question is:
Do I have to remover the stater and everything including the gear/stater housing to get this seal out and replace it or is there a way to replace it w/o removing this housing.
Trooper
Old Dec 23, 2006 | 11:27 AM
trooperK's Avatar
No mechanics out there or anyone who has done this repair??????????
Trooper
Old Dec 28, 2006 | 07:49 PM
Polaridoo's Avatar
More than likely it is the mechanical seal - its a ceramic seal. Just double check that it is not coming from the waterpump cover and its seal.
It's been several years since I replaced the mechanical seal but I remember pulling the flywheel and maybe the pickup coils. If you have tinkered on ATVs/Motorcyles/Snowmobiles then it's easy. I think the whole job maybe took about 2 hours. And there is no other way to replace other than pulling off the plastic ignition cover, flywheel, etc. I took some digital pics way back - if you want to see them I can show you.
Old Dec 29, 2006 | 02:02 AM
itstillruns's Avatar
getting the pump(impellor) and seal out is pretty simple if you are decent with tools. The starter and stuff stay in. Just the floorboard and engine cover come off - get the parts book down loaded from polaris website, it makes repairs alot easier.
Old Aug 6, 2007 | 02:24 AM
snowguy's Avatar
TrooperK, did you fix the water pump seal yourself? I'm having the same problem/question on my 04 and had the same questions you did. The shop manula doesn't really make it very clear on what all is involved. Anybody else?
Old Aug 6, 2007 | 11:30 AM
trooperK's Avatar
Snowguy,
Oddly enough it just stopped leaking. It hasn't leaked a drop since I wrote this post. It could have been the cold weather but I've put about 1000 miles on it this summer and it's fine. I may however be replacing it this winter [img]i/expressions/face-icon-small-smile.gif[/img]
Trooper
Sandman2.0
Jul 21, 2015 09:03 AM
clsharky
Jul 13, 2015 02:07 PM
John Boy
Jul 13, 2015 11:16 AM
steveo612
Jul 11, 2015 08:35 AM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
