Piston Weight Torque vs HP
Old Dec 20, 2006 | 11:33 AM
ERBEDS650's Avatar
Default Piston Weight Torque vs HP
OK heres oldie but a goodie!
I understand lighter the piston faster it can rev, and can make more HP on a Dyno,but what piston makes more torque? say 100mm 12 1/2 to 1
1 piston is 515 grams and the other piston is at 535 grams, will the heavier piston make more torque?
222 and MR HP, and OMR wrote on this way back when.
Old Dec 20, 2006 | 02:18 PM
azdave's Avatar
The heavier would more than likely make more low end tq but lose it's advantage up higher - me thinks... Not sure tho. I do know that lightwieght flywheels on 4cyl Honda engines typically make more HP and TQ up in the higher RPM's, tried several different weights and found that on a high compression motor the lighter the flywheel the better. Now obviously I would think that every setup would be affected differently by any rotating wieght/mass.
Prolly not worth a crap but thats my 2 cents. LOL
exmotocrosser
Sep 13, 2019 06:12 AM
dannytas
Sep 26, 2017 06:31 PM
Robinhood
Dec 26, 2015 10:28 AM
2many2ride
Sep 27, 2015 04:35 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
