RELOCATE BATT QUESTION, upside down? flat?
Old Dec 21, 2006 | 08:30 PM
shmee's Avatar
Default RELOCATE BATT QUESTION, upside down? flat?
moving the stock batt "yuasa" has anyone layed them sideways? flat? no problems? they are sealed and the web site said its not good but it can be done?
i seen jeffros is and biggerisbetters are layed down.
WHO HAS DONE IT.
any leaks?
batt going bad?
i know i can get the odessy pc545 but there is nothing wrong with the stock one.
Old Dec 21, 2006 | 08:47 PM
FatHolly's Avatar
I don't think you can lay the stocker flat... I'm pretty sure the one they had at my dealer needed to have water added, hence not a sealed battery. I could be wrong... it happened once before.[img]i/expressions/face-icon-small-wink.gif[/img]LOL
Old Dec 21, 2006 | 09:27 PM
CALDS650's Avatar
The Odessy can be laid down sideways
Old Dec 21, 2006 | 09:32 PM
AZSAND's Avatar
THAT!!!!!Sounds down right sexy!
No you can not lay a lead acid battery on its side if you could manage to keep the electrolitye in the battery. You will cause one plate to starve for electrolyte and sulfate up causing the battery to short and this normaly happens rather fast.Because the lead is stored under acid therfore it is completely etched as soon as the air hits it it will accelerate corrossion. Go with a gel cell.
Old Dec 21, 2006 | 10:00 PM
amd's Avatar
amd
Yeah Azsand is correct. check out my pics on my page, and look at how I mounted mine.
Old Dec 22, 2006 | 12:30 AM
shmee's Avatar
alright, alright, ill put it up front.
Old Dec 22, 2006 | 02:07 AM
DSNUT's Avatar
Originally posted by: AZSAND
No you can not lay a lead acid battery on its side if you could manage to keep the electrolitye in the battery. You will cause one plate to starve a for electrolyte and sulfate up causing the battery to short and this normaly happens rather fast.because the lead is stored under acid therfore it is completely etched as soon as the air hits it it will accelerate corrossion. Go with a gel cell.
AZ - that was very technical and well said! This post is truth.
Old Dec 22, 2006 | 02:21 AM
MrMeaner's Avatar
Looks good AMD. I mounted mine in the center under the seat. I run a clamp on now and there is plenty of room. Ill get some pics up of mine soon and see what you guys think.
Old Dec 22, 2006 | 03:39 AM
MrMeaner's Avatar
I submitted some pics of my relocation and 2 subframes. One with the box removed and one without. I also posted a pic of the stock box weld to the back
Old Dec 22, 2006 | 06:56 PM
shmee's Avatar
Yes, that battery can be mounted in the positions listed, because it is
a Non-Spillable battery.
The same battery, supplied with a separate acid pack, called the
YTX15L-BS, can not be tilted.
Alan Kohler
Yuasa Battery
THIS IS RIGHT FROM THE COMPANY.
so it looks like it would be fine.?.?
