trail blazer under powered?
Old Dec 28, 2006 | 01:00 AM
Corey64's Avatar
Default trail blazer under powered?
Hey I got a 96 trail blazer. I realize that it is only a 250 and its not a speed machine at all. But I have seen numerouse pictures of people cat walking these things with the front wheels a good foot or more in the air. I cant even get mine off the ground at all. Is there a problem with mine or do these other people have mods that I dont? Thanks
Old Dec 28, 2006 | 07:58 AM
ftwflh's Avatar
If yours hasnt had a fresh topend do that and while your at it add a good pipe with matching clutch kit.Then your will run great.
Old Dec 28, 2006 | 04:17 PM
Corey64's Avatar
I have thought about the clutch and pipe and I most likely will do that. As for a fresh top end from my understanding dotn I only need to redo that if I am loosing compression? Thats just what I have always been told. Thanks
Old Dec 28, 2006 | 08:15 PM
godIlove2ride's Avatar
I run a 95 Trail Boss 250 with no mods and no rebuilds, and I can pull the wheels off the ground just fine. Not to mention that it's as fast as my Ozark which is only 6 months old.
Old Dec 28, 2006 | 08:48 PM
x_scrambler3's Avatar
With the TB you can mod them pretty good just depends on what you have to spend. Mine is pretty highly modded an there is still a mod left to do. If you find a used 34mm carb fron a Polaris 400 motor it can be put on you TB an an get a clutch kit will get the front tire of the ground.
Old Dec 29, 2006 | 01:46 AM
Corey64's Avatar
Well if you can manage that I should be able to get mine up wouldnt you think? Any ideas on what could be causing mine to be underpowered? Could the muffler be carboned up? Thanks again
Old Dec 29, 2006 | 08:07 AM
Might need to be rejetted could be needs a new belt replace the secoundairy buttons need replacing, air cleanner there is alot of small thing that can effect it.
Old Dec 29, 2006 | 09:09 AM
kickass210's Avatar
dude how tall are u and how much do u weigh?
Old Dec 29, 2006 | 10:07 AM
You say it's underpowered. Does it bog down under acceleration? Is it cutting out. Give us an idea of some of the things that it does then we can better help you.
Old Dec 29, 2006 | 11:07 PM
onesavage's Avatar
i just replaced the crank seals on my wifes and it runs much better.but this was doggy and got hot.she will pull the ft up on a bad day!!!!. rider weighs 135 @ 5"5
