Scrambler oil injection ??
Old Dec 29, 2006 | 07:15 AM
450trailrider's Avatar
Default Scrambler oil injection ??
I have just recently installed a Hpd pipe/ Silencer, Clutch kit, Overbored carb and Rad Valve. I am concerned now about the amount of oil that the injection is feeding. It is apparently working but I see absolutley NO SMOKE behind me. I am using the Polaris "Gold" injection oil. If I remember correctly, I increased my jetting to 30 pilot and 280 main and it is pretty accurate.
Are these injectors adjustable?
How much should it be injecting?
Old Dec 29, 2006 | 08:02 AM
ftwflh's Avatar
The no smoke issue is why I dont like the gold.I run the regular Polaris 2stroke oil.
On adjusting the oil pump your manual goes into it real good.You can bump it up some but best to adjust it to where it is suposed to be set at.
Old Dec 29, 2006 | 08:50 AM
It would smoke a little every now and then stock but it seems like it has absolutley none now.
Old Dec 29, 2006 | 12:00 PM
BigBlueScrammy's Avatar
This link should help you or anyone else who does not have their manual handy.
Oil Injection adjustment
exmotocrosser
Sep 13, 2019 06:12 AM
Matt123
Sep 29, 2015 01:29 AM
exmotocrosser
Sep 26, 2015 08:18 AM
Nosparkpolaris
Sep 20, 2015 04:21 PM
1000gade
Sep 9, 2015 03:35 PM
