I need a pic of 800 exh
I have an 800 header that I am going to put on the MV. The pipes mounts differently. My dealer has no 800's in stock to see the way an 800 mounts. I have a parts list of what is needed, I just want to see a pic of one installed. I only need the mounting connection in the pic! Thanks
I never got this pic from my old 800[img]i/expressions/face-icon-small-frown.gif[/img]
That seems odd, I thought the 700 and 800 would be the same, allowing the pipe to bolt up. I wonder what is different. Oh, I just thought of something, the years difference may plays a role, your quad is '03 and that pipe "fits" an '05-07! Guess it really doesn't matter if it bolts up or not. Thanks again.
Instigator:
At the end of Feb 06 they changed to a two-piece header. The split is right after the "Y". There is a support mount that is already welded to the frame on mine. Looking at the Polaris site on the 07's that is for a rubber support and spring. I don't have the two-piece or I would send you the pic. I can take a picture of the mount that is on my frame if you like. I did get the improved heat shield that combines the front two shields as seen in my pics. It will work for the two-piece header as well.
Totun
Totun
I didn't know that th new ones had a 2-piece pipe. Mine is a one piece, my dealer had it in stock. It was ordered for a guy, but he never picked it up. The early pipes rubbed something, I think it was the engine, anyway this is a redesigned pipe to correct that problem. I think that I will not worry about the mounting. I am going to ensure a good fit, then if all is well, I am going to send it to Jet-Hot. I see yur is coated, who did it for you? Do you like the results? Does the mud clean off any easier from the pipe?
