clutch buttons
Old Jan 3, 2007 | 10:11 AM
onesavage's Avatar
Default clutch buttons
o4 sportsman 400 i had my secondary clutch apart to set it to 1/1 and noticed that the buttons were very worn kindof burnt in this normal at 1300 miles . should i replace w/ polaris or does a aftermarket company make better ones..also would puting a differnt spring in do any thing thanks
Old Jan 3, 2007 | 07:57 PM
sportsman40005's Avatar
I replaced my buttons about a month ago. I think I set mine on 1-2 ? someone here posted what the different settings were ,but I forgot. Mabe he can post those settings again. As for stock of after marked .I was advised to go with stock. I couldn't find any after market anyway. Mine went with about 40-50 hrs on the meter.
Old Jan 3, 2007 | 08:27 PM
STARKSREBEL's Avatar
dennise kirk sells aftermarket buttons in there snowmobile mag.there the same as the atv.
Old Jan 3, 2007 | 08:32 PM
caperinmuskoka's Avatar
Ride like you own it, Not like it's stolen!
How do you know if they are worn?..Do they start making a high pich noise like the sleds do?....Caper....
Old Jan 3, 2007 | 08:34 PM
you can look at them and see if there worn.
Old Jan 3, 2007 | 08:37 PM
[quote]
Mine started shifting differently. If I was in low & wind the motor up it would appear to shift inot a higher gear. My buttons were bad .I had to buy a new ramp as it started to wear with the buttons gone.
Old Jan 3, 2007 | 08:43 PM
that will happen if you do not catch it in time.the ramp you speak of is called a helix and comes in different angels of degrees for your performance preference.
Old Jan 3, 2007 | 08:49 PM
I didn't know you could buy different degrees. Ihave heard it called a helix polaris (I think ) calls it a ramp in the parts book.
Do you know the different settings for the rear clutch ? When I was working on mine someone posted the settings & I don't know who it was.m or how to look it up
Old Jan 3, 2007 | 08:53 PM
the book suggest 1 & 2 holes what the settings do is affect your upshift and backshift of your secondary clutch (the rear clutch)
Old Jan 3, 2007 | 08:58 PM
onesavage's Avatar
hey thanks ,thats what i wanted to hear.....have you tried a clutch kit yet ,,,hopeing to find someone that has a 400 w/ a clutch kit.... i am note to sure if it will do anything being a single cyl 4 stroke w/ a carb... but looking forward to a good review so i can make the upgrade
