clutch buttons
Old Jan 3, 2007 | 09:51 PM
  #21
Lukester's Avatar
Default clutch buttons
Thank you for the secondary spring installation - good info..
Went to Heelclicker and reviewed secondary installation and adjustments. After review, I have to wonder if my 03 Trail Boss is factory set at 2-2? Any help?
Old Jan 3, 2007 | 10:42 PM
  #22
STARKSREBEL's Avatar
thats the easy way of doing it.i did it the other way to get the exspearyence from it.
Old Jan 3, 2007 | 10:44 PM
  #23
if you are the first owner of the bike it might be.if not it is probably 1 & 2
Old Jan 3, 2007 | 10:45 PM
  #24
sportsman40005's Avatar
Originally posted by: onesavage
yea i see that, at the risk of sounding like a dumb*** shouldnt i just buy a kit.. i couldnot tell you what differnt weight /spring combos do. and get it right
I called that company & when I told him my tire size ,it seemed to tick him off . He went on to tell me that I needed to sell my tires & install stock size tires he named some type that good year makes that my 400 only produced 15 H.P. & his clutch wouldn't work with that tire set up. As you can see ,I kept my big tires. I did change my rear setting to the stiffest setting & went with a white spring on the front.
Old Jan 3, 2007 | 10:51 PM
  #25
how does it engauge with the white spring?does it rev up any before engauging the belt or what?
Old Jan 3, 2007 | 11:18 PM
  #26
Yes , with the white spring you have to give it a little more gas to take off . Higher rpm to engauge the clutch
Old Jan 4, 2007 | 01:49 AM
  #27
i have to do the same with the orange spring but the rpm engaugment isnt that high.you can call my cell if you need to talk about this 337-515-4534
Old Jan 4, 2007 | 11:43 AM
  #28
onesavage's Avatar
starks rebel,,,, i would like to talk w/ you about my clutch set up and get some of you input ,,,sounds like you he clutched a sporty 400 and know what you are doing.. if i can add some weights and a spring thas gota be about 100.00 cheaper than a kit
Old Jan 4, 2007 | 02:30 PM
  #29
no problem call my cell 337-515-4534
Old Jan 4, 2007 | 06:20 PM
  #30
onesavage's Avatar
thanks is it ok to call after seven, free time on nextel .. by the way my name is mike
