Scrambler help needed!!!
Old Jan 3, 2007 | 09:36 PM
2000scrammy's Avatar
Default Scrambler help needed!!!
My 2000 Scrambler 400 is driving itself sometimes. I have had the throttle stick at wide open a few times now the last couple times out and it's almost clotheslined me on a volleyball net at 50-mph and ran itself into a pond. I can't figure out what's wrong with it. It's been really delayed when I let off the throttle too like maybe a half-second before it starts to slow down at all. I tried looking at the cable itself and it doesn't seem to be stuck at all anywhere and I tried spraying WD-40 down the cable but that didn't help either. Also when it's not running if you just push the throttle it comes back just fine it only seems to happen when I am riding it.
Old Jan 3, 2007 | 09:58 PM
caperinmuskoka's Avatar
Ride like you own it, Not like it's stolen!
This happened with my wife's snowmobile....It was the cable ....SMALL fray on the cable inside the housing.....I could not see it but the dealer replaced it and worked fine after that!!!!......Caper...
Old Jan 3, 2007 | 10:01 PM
Do you happen to remember how much that cost, also how does that even happen. I guess it's just one of those weird things, huh. Oh well that's somewhere to start I guess, thanks
Old Jan 3, 2007 | 10:04 PM
x_scrambler3's Avatar
mine went bad on my 98 to an I changed mine an it fixed it but the cost around $70 for a polaris one. I got one through HPD but I have the the single cable so now I premix the gas but there was under $40
Old Jan 3, 2007 | 10:24 PM
ftwflh's Avatar
The original cable is over $100 but I think well worth it.Or go with the premix
Old Jan 4, 2007 | 03:27 PM
Wow I didn't think that a throttle cable would cost that much money. Is there anythign else that it could be though or is that just where I should start with a new cable?
Old Jan 4, 2007 | 04:39 PM
scrammersam's Avatar
mine somehow fixed itself so i think i just had some dirt in it. i would take it off and inspect it before you buy a new one
Old Jan 4, 2007 | 05:38 PM
DaveinTucson's Avatar
Hi-
My Scrambler 400 ( a 1999) has had the throttle sticking a little lately - which I have been expecting for some time. In the 1999 model, there was a recall of the throttle control mechanism on the handlebar. It is the fairly large module where the thumb-switch is attached (it is meant to prevent the throttle from sticking if the engine is in nuetral, I think). Polaris issued a recall, as the mechanism was malfunctioning. I plan on taking mine in, and the dealer should bill Polaris for this, making it free for me. I don't know if a 1999 recall affects a 2000 model, but I'd bet that it's at least worth a phone call to find out........they don't usually redesign all of their parts each year.
Old Jan 4, 2007 | 09:20 PM
BigBlueScrammy's Avatar
The cable is a complicated design. It has one cable that turns into two. You have to lube both the handle bar end and the carb and oil injection end. It may even be necisary to open the junction of the cable and lube inside that. Make sure the inside of the throttle housiing is clean as well. One other thing that can cause this is hand grips. If you've installed new grips latetly, make sure the throttle lever is not getting caught on the grip flange. I've seen this happen and had it happen to me personally.
Old Jan 4, 2007 | 10:31 PM
matthewvi's Avatar
I had the same thing with my new grips. I knew it, but I forgot to tell my friend [img]i/expressions/face-icon-small-smile.gif[/img] He had a scary moment in the woods! LOL!!!
