very weak spark 250 trailblazer
Old Jan 4, 2007 | 01:16 AM
maltaknights's Avatar
Default very weak spark 250 trailblazer
Hi, I have a 2000 250 Trailblazer. The spark is very, very weak--I can hold on to it and I can barely feel it. It had been running fairly well, but then it started to miss. If I would press the override button, it would clear up and run fine. One time, I turned it off after riding, came back five minutes later, and it wouldn't start.
I've tried a different coil, kill switch, and I bought a new battery. These didn't help.....any suggestions? Thanks.
Old Jan 4, 2007 | 02:07 AM
STARKSREBEL's Avatar
check the circuitboard.on it is a set of purple wires,pull the large purple wire and see if that will help.it should disingauge the limiter.
Old Jan 4, 2007 | 07:42 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
if pushing the override made it run fine than its a problem w/ in the limiter. unhook it to see if it does run fine.
Old Jan 12, 2007 | 11:12 AM
Thanks for the info I put a new kill switch and override button on it and I still cant get any spark, I switched the coil out and still nothing
the only thing I can think of it being is the stator. any suggestions? Thanks.
Old Jan 12, 2007 | 06:05 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
if you done everything esle then most likely it is the a bad stator.
neo27ny
May 14, 2018 12:19 PM
tmboy
Technical and How-To Articles
Sep 1, 2015 09:20 AM
hueby
1) Engine problems..
Aug 29, 2015 08:34 AM
hueby
Aug 28, 2015 07:26 PM
suzukiquadrunner1987
Aug 6, 2015 03:59 PM
