Recon Hand Warmer Help
Old Jan 4, 2007 | 10:11 AM
sissabagama's Avatar
Default Recon Hand Warmer Help
I need some help determining which power wire (switched) to tap into for the power to the hand warmers. If anyone has installed hand warmers or other switched accessory on a Recon, could you tell me which wire and where to connect to it? Did you worry about waterproofing it?
Old Jan 4, 2007 | 02:34 PM
hondabuster's Avatar
You can tap into the nuetral light or reverse light wire. Just do it on the positive side before the bulb, or the bulb will come on whenever the handwarmer is used( if you tap into the wires after the bulb). Those wires are powered with the key on at all times, the light only comes on when the switch makes a ground.
Put a 3 amp fuse in line with the handwarmer, just in case you get a short, itll protect the wire circuits, of the quad.
Old Jan 5, 2007 | 08:07 PM
recon342's Avatar
i put spot light on my recon one time u can buy a power outlet like a cigerate liter and hook it to your batter and then have it stick out in the little hole were your seat latch is the put a plug on the hand warmers and run your wires under your seat so they want be in your way and u can put a switch on your warmers[img]i/expressions/face-icon-small-tongue.gif[/img]
Old Jan 6, 2007 | 12:50 AM
hondabuster,
Please check your private messages
Hack714
Sep 26, 2015 08:11 AM
MikeyBoyesq
Sep 22, 2015 10:02 AM
01ssls1
3) General Discussions..
Sep 21, 2015 12:23 PM
MikeyBoyesq
Sep 7, 2015 10:44 PM
Jason Campbell
Sep 7, 2015 02:25 PM
