loose axle nuts
Old Jan 6, 2007 | 01:13 PM
lucasislight's Avatar
Default loose axle nuts
sorry about that blank post...
anyways, i am having problems keeping my axle nuts tight while riding, when we stop for a break, sometimes they are hand loose! i tighten them with a pipe wrench that i stand on when tightening, so i know initially they are VERY tight. anyone with the warrior have this problem, should i use threadlock or get a nut with a set screw (raptor?) thanks for the help.
Luke
Old Jan 6, 2007 | 02:16 PM
ATV_MAN's Avatar
Ya maybe install a new nut, but I think the threads on the axle wear out over time from vibration and make the nut sit loose when it should be fairly snug. You can try threadlocker but use the blue stuff, it wont be permanant and wont hurt the threads.
Old Jan 6, 2007 | 05:32 PM
Speedy2222's Avatar
Is A Power Sport Junkie!
i had this problem not too long ago.. i put some blue loc tite(all i had) tightend the first
then tightend the 2nd and then put my foot on it and gave it some good pressure... then let it set for about 2 days
Old Jan 6, 2007 | 06:55 PM
i went riding today and rode it hard and the nuts stayed put. i really stood on the wrench this time, but i think i will get the blue stuff and it should be ok. does anyone know if the raptor axle nut with the set screw will even fit the warrior?
Old Jan 6, 2007 | 09:47 PM
velocyraptor's Avatar
dont use the blue loctite, use the red loctite and you could do what desert racers do, tape the nuts with ducttape.
Old Jan 6, 2007 | 11:58 PM
BassBlaster's Avatar
uuuuuuummmmm No use the blue. If you use the red, it is a permanent fix and you will not be able to service the axle when it comes time. The blue is serviceable. We used to use the red stuff on bolts in the limestone plants and you had to cut the bolts with a torch when it came time to work on something. That stuff is really strong.
Old Jan 7, 2007 | 01:00 PM
fastblaster00's Avatar
do u have the cotter pins in? maby some blue lock tight
Old Jan 7, 2007 | 02:37 PM
i use red loctite and it is serviceable, you just need to know how much to use
Old Jan 7, 2007 | 05:20 PM
ATV_MAN's Avatar
He's talking about the big axle nuts near the middle, not the hubs.
Old Jan 7, 2007 | 06:58 PM
JLsparky7's Avatar
Red loctite is usable and breakable. The red is about twice as strong as the blue therefore you can use 1/2 as much and get the same result. Its the green stuff thats wicked. It accually holds better than a weld :-o I went to the loc-tite factory back in the paintball days and they explained it all to me. Even if you use to much red loc-tite a little heat breaks down the chemical compound.
