re-jetting banshee
Old Sep 17, 1999 | 12:12 AM
bansh22's Avatar
I just got my banshee and iam getting some pipes for it. Since I will have to re-jett it i need to know if I have to take-off the anti-stuck throttle things that are on top of the carbs, and if i do how. thanks
Old Sep 17, 1999 | 12:25 AM
fastblast's Avatar
I have a Blaster, but still, the "anti stuck throttle things" are just little switches in those big boxes on top of the carbs. The boxes house an arm used to reduce throttle pull. I removed the switches permantley just to make stuff simple, but I DON'T reccommend it. The whole box should just unscrew from the top of the carb and you shouldn't have to even mess with it(referencing to blaster carbs). You'll have to pull the carbs and remove the float bowls, then unscrew the brass jet that sticks up high in the center of each carb and replac eit with the new one.
hope that was enough and not too much and relevant
fastblast
Old Sep 17, 1999 | 09:13 AM
blue_banshee's Avatar
if u get a jet kit with the pipes which u should then it will tell u all about how to do it...it is a sinch
Kaleb_00
Jun 1, 2016 09:15 AM
greek271
Aug 8, 2015 08:16 PM
JohnnySplat
Aug 6, 2015 12:07 PM
Dirtbikemike1
Jul 11, 2015 03:36 PM
Jul 7, 2015 11:00 PM
