Wont Start
Old Jan 14, 2007 | 02:46 PM
one8upcb's Avatar
Default Wont Start
Here is what i Know. JetMotto, It has spark, it gets fuel, battery is charged. and it just turns over and over. I'm am lost at this point and dont know what to check. any ideas please right back. Oh and bike is in neutral.
Old Jan 14, 2007 | 03:38 PM
QWODER's Avatar
Default Wont Start
It might help if we knew what kind of bike it is.Drain the fuel out of carberator.might be a screw on the bottom of carb you can turn and drain carb.Try this for starters.
Old Jan 14, 2007 | 03:51 PM
one8upcb's Avatar
Default Wont Start
the bike is a jetmotto 125. drained fuel from carb. cleaned carb and jets,checked spark, new plug, turns over but won't fire. won't start even using starting fluid!!!!
Old Jan 14, 2007 | 08:35 PM
one8upcb's Avatar
Default Wont Start
anyone with any ideas.
Old Jan 14, 2007 | 08:46 PM
reefskinner's Avatar
Default Wont Start
Have you adjusted the valves? Checked for compression?
I had a 90 falcon drop a valve on me, may want to look in that direction.
Shawn
Old Jan 15, 2007 | 08:52 AM
one8upcb's Avatar
Default Wont Start
I havent checked the valves. But I did check the compression and we are good there. The only other thing i can think of is its not getting a hot enough spark. Cause it doesnt fire with starting fluid either.
Old Jan 20, 2007 | 08:43 AM
VenturiVic's Avatar
Default Wont Start
I just went through this. Three things to check.
Try bypassing the kill switch. I had a problem with my Redcat where I got spark, but it was expreamly weak, not enough to fire the engine. I bypassed the kill switch and it fired right up!
Also, get rid of that NGK crap spark plug and get an Autolite! NGK's are garbage! If you havnt replaced the plug yet, do that no matter what.
Old Jan 25, 2007 | 02:31 PM
Drifter463's Avatar
Default Wont Start
If it has run before and turned off by the shut off switch, make sure you push the button in to reset it... I keep for getting to do that... 2nd if you still have the stock battery you may want to see about getting a new one... We had that problem (it would crank but not start) and a new battery fixed that... Hope that helps...
Old Jan 25, 2007 | 05:53 PM
one8upcb's Avatar
Default Wont Start
when you say push the button in. Where is this button located.
Old Jan 25, 2007 | 06:31 PM
Drifter463's Avatar
Default Wont Start
It on the left handle (mine is at the bottom and its red)... It's your kill switch... You can turn the bike off by pushing it to the Right or Left... You must reset it before the bike will start... Just push it in...
