Wont Start
Old Feb 20, 2007 | 10:22 AM
  #21
godIlove2ride's Avatar
Default Wont Start
Again try a new plug. I had a Polaris Trail Blazer that did the same thing, and it was all because of a cracked insulator on the spark plug. Try a new plug.
Old Feb 20, 2007 | 12:09 PM
  #22
kazumaaa's Avatar
Default Wont Start
check intake tube from carb to motor if it has crack it will not start
Old Feb 20, 2007 | 04:13 PM
  #23
jschick's Avatar
Default Wont Start
this is interesting because I have the same problem with my warrior. I have good timming, fuel, spark and compression. but it does nothing at all not even a spit or sputter, I have tried 3 different plugs, checked the valves, the carb, my only guess it the spark is not strong enough. starter fluid does nothing at all. not sure if it is the coil, the CDI, or pickup. but visually I get spark, but can't conclude if it is strong enough.... Very courious to see how you resolve your no start!!!!!
Old Feb 20, 2007 | 04:33 PM
  #24
one8upcb's Avatar
Default Wont Start
Well i tried a 2 new plugs this time with the same results. I will have to check the intake tube to see if it has a crack. How are these things timed. It seems as if the spark isnt hot enough or its jumping the timing. any more feedback is greatly appreciated. thanks to all
Old Feb 27, 2007 | 10:59 AM
  #25
mlb2199's Avatar
Default Wont Start
Replace the coil. Mine as well as another post had the same excact problem.
Old Feb 27, 2007 | 04:36 PM
  #26
mywifesquad's Avatar
KTM Patrol
Former Chinese POW!
Default Wont Start
Welcome to the forum one8upcb! [img]i/expressions/face-icon-small-smile.gif[/img]
Is this a new quad and what color is the spark your getting?
Old Feb 27, 2007 | 07:40 PM
  #27
one8upcb's Avatar
Default Wont Start
Its a fairly new its an 05 or 06 with about 4 hours on it. i guess the color of spark would be best described as a lighting bolt with maybe blue at the tip. John at raceway told me to take it to the shop but i just havent had time.
Old Nov 4, 2007 | 02:52 PM
  #28
mikester4586's Avatar
Default Wont Start
Hey what I did because, I had this problem I bout a new hotter spark plug. Also check the wiring.
Old Jan 27, 2008 | 11:49 AM
  #29
Default Wont Start
Hey I had the same problem, I was told to clean the carbs out and to check the petcock int he tank. Also clean your tank out and replace the fuel filter. That should do it, also check if there is a air leak in that intake boot. I did all those steps above and ours still didn't work, until I found a cut in the intake boot I am buying a new one, if it works I will tell you and make sure that your carb float is adjusted right and that the screws are tight but not too tight. MIKE
P.S. you might want to try a hotter spark plug.
MikeyBoyesq
Nov 27, 2020 02:44 PM
Mkp
Mar 28, 2020 03:50 AM
tiresharkdbb
Sep 3, 2017 02:06 AM
garyt1975
Jun 5, 2015 08:53 AM
1000gade
May 27, 2015 12:37 PM
