Do you have a problem starting the 700fi when its cold
Old Jan 15, 2007 | 02:20 PM
downeaster's Avatar
Default Do you have a problem starting the 700fi when its cold
I did this past week, and the problem turned out the dealership when changing the breakin oil
used 10W40 oil, and not the cold weather version 5W30CW for atvs. After changing the oil the Griz
starts like it is summer. Some of you may also have this identical problem.
Old Jan 15, 2007 | 02:23 PM
squeege's Avatar
HHMMMM.............Would a 660 start with the same oil
If so, it would seem the problem is in the EFI settings
Old Jan 15, 2007 | 02:47 PM
v2rider's Avatar
Very interesting........................
Old Jan 15, 2007 | 08:52 PM
JLsparky7's Avatar
Amsoil 0w40 is the only way to go. Especially in the winter. Flows like water when its cold then gets thick.
Old Jan 15, 2007 | 08:57 PM
lafngas's Avatar
I run 10w30 yamalube and mine starts fine but, I do have a problem with it stalling. It seems to be the worst when its hot like tonight when I was plowing my drive way after the storm . It just kinda pops and dies and then starts right back up. If any one can help me figure this out and fix it that would be great! Thanks
Lafngas
Old Jan 15, 2007 | 09:15 PM
JLsparky7's Avatar
Lafngas
Read what this stuff does and let me know what you think. Its probably poping from overheating, fan working right?
https://www.amsoil.com/storefront/aff.aspx
Old Jan 15, 2007 | 10:08 PM
DesertViper's Avatar
Mine won't start if its left outside overnight at temperatures less than 10 degrees. If I keep it in my garage it starts and runs fine, even at very cold temperatures (-19 is the coldest it has been in yet). There is no popping or stalling once it is running at low temperatures, it just wont start to begin with. And I mean it absolutely will not start, not that it is just difficult to start.
DV
Old Jan 15, 2007 | 10:48 PM
v2rider's Avatar
I also believe Amsoil 0-40 is the best synthetic oil to use
Old Jan 15, 2007 | 11:24 PM
JLsparky7's Avatar
My kinda dude, no i dont mean that in a homosexual way....
Old Jan 15, 2007 | 11:25 PM
JLsparky7's Avatar
DV
Give amsoil 0w40 a shot, If that doesnt work then hook it up to the battery charger when you try to start it.
