03 warrior looses spark,???
Old Jan 15, 2007 | 07:47 PM
burrrrrrrop's Avatar
Default 03 warrior looses spark,???
Hey everyone,new to the boards here. I just picked up an 03 warrior. It has pretty good spark when taking the plug out and checking it against a ground. A few days ago it didnt have any spark. I can get the quad to run for about 5 seconds but then it dies. Im thinking its loosing spark. I took the stator out but dont have a manual to get the specs to check it with an ohm meter. Trying to fix it asap and no one has a manual in stock. Does my symptons sound like the stator/pickup going bad or could it be the cdi or coil? thanks in advance for the help!
Old Jan 15, 2007 | 08:58 PM
Speedy2222's Avatar
Is A Power Sport Junkie!
register at stuntlife.com
then go to this link
http://www.stuntlife.com/forums/41-q...g-diagram.html
Old Jan 15, 2007 | 09:06 PM
Good info but nouthing on spark,stator etc.
Old Jan 15, 2007 | 10:27 PM
Speedy2222's Avatar
do u have aim by chance? or any other instant messanger?
Old Jan 16, 2007 | 05:11 PM
Ok put the stator back in b/c i wanted to check the revese lever. I grounded out the green wire and it still does the same thing. new plug,grounded the reverse ,and it rusn for about 30 seconds then dies. just ordered a new Ricky stator .picup etc. So well see if that does it. [img]i/expressions/face-icon-small-confused.gif[/img]
Old Jan 19, 2007 | 10:32 AM
New stator ,still no spark. I want to check the coil but cant find the procedure in the manual to do so. [img]i/expressions/face-icon-small-disgusted.gif[/img]
Old Jan 19, 2007 | 12:08 PM
fasterthanyou22's Avatar
Do an ohms check on the wire leading to the plug, it could be frayed inside or corroded. Check every hot wire leading to the plug. You should have done that before investing in the stator.
Old Jan 19, 2007 | 12:21 PM
coil is good. 4 ohms. I just checked power to the coil and the coil isnt getting any power (orange wire)
Old Jan 19, 2007 | 12:24 PM
Check the power source of the orange wire. The orange wire could be damaged.
Old Jan 19, 2007 | 01:49 PM
the stator i bought from ricky stator,who ever assembled it, had to wires mixed up. good to go now!
Reactant
Mar 30, 2022 02:08 AM
STLyamwar
Jul 25, 2020 04:44 AM
gorylewis
27
Oct 4, 2015 05:22 PM
manuelrivera
Aug 8, 2015 04:34 PM
suzukiquadrunner1987
Aug 6, 2015 05:29 PM
