Raptor Or YFZ 450 Suspension On A Warrior
Old Jan 18, 2007 | 08:23 PM
Raptor450's Avatar
Default Raptor Suspension On A Warrior
Aybody out there know how to upgrade the suspension on a Warrior/Raptor 350 using Raptor 660 or YFZ components and what would be involved? I have Works shocks on the front, +2 A-arms, and a +4 Durablue axle, but Im still not happy with mine. Any ideas? (besides buying a new bike)
Old Jan 18, 2007 | 08:25 PM
Speedy2222's Avatar
Is A Power Sport Junkie!
the raptor fronts would be too soft.. you could use em but they def would be too soft.. maybe have em revalved
Old Jan 18, 2007 | 09:22 PM
recon99's Avatar
Default Raptor Or YFZ 450 Suspension On A Warrior
First, raptor or yfz shocks are going to be too long. They may fit without stressing the ball joints too bad since you have aftermarket arms, but they're still not going to work right. They're designed for different suspension geometry, and yfz shocks ride like crap even on the yfz. If you're unhappy with your works shocks, for whatever reason, upgrade to a better aftermarket shock like Pep, Ohlins, or Elka. What is it you don't like about the works anyways? You know you can get them revalved and re-sprung?
Old Jan 18, 2007 | 09:59 PM
Raptor450's Avatar
The Works were a HUGE improvement over stock, but its like they are too soft. I just bought them new last year, maybe they just need to be stiffened up some. Works was supposed to set them up for my weight, maybe they didnt. Does anyone know how to adjust them? The ones I have are dual rate and are supposed to be ride height and spring rate adjustable, but I didnt get any instructions and havent found anything online. I was just wondering how YFZ or Raptor shocks would work on a Warrior. I wouldnt think they would work too good. I saw where someone on the forums said they had some on theirs, I was hoping they would reply, but I forgot who it was.
Old Jan 18, 2007 | 10:04 PM
recon99's Avatar
Were the shocks sprung and valved for the extended arms?
Old Jan 19, 2007 | 01:49 AM
Raptor450's Avatar
Well, they were "supposed" to have been. Not that it means a whole lot, but I bought the A-arms and the shocks at the same time from the same place, and I told the salesman exactly what I was putting ALL of this stuff on and my body weight, because he asked this info so "they could setup the shocks for me", but who knows what they did. What do you suggest I do?
Old Jan 19, 2007 | 08:06 AM
recon99's Avatar
I'd try to get the works shocks to perform to your likings. I don't have any complaints about mine. First try tightening up the spring preload, and if that doesn't work, send it back to works and get them to set them up different.
Old Jan 19, 2007 | 12:03 PM
warpigs's Avatar
Sounds like he gave you the runaround, I love my works shocks, check out the works web page or call them, they will be able to clear anything up. Sometimes when you buy from an outside dealer they give you what they had laying around and tell you what you want to hear to make the sale. But IMO their very good shocks so give works a call and straiten things out.
Old Jan 21, 2007 | 04:05 AM
Raptor450's Avatar
Your signature says "full Raptor suspension in under $50". I dont understand how you could say you have it on yours, but it will be too soft on mine.[img]i/expressions/face-icon-small-confused.gif[/img]What setup do you have on yours and if you have Raptor suspension, what was involved on installing it? Please help me here.
Old Jan 21, 2007 | 10:16 AM
Speedy2222's Avatar
i have stock a arms..
you have +2 a arms.. depending on the a arm.. they'll most likely be too short and prolly be too soft due to the angle
Robinhood
Dec 26, 2015 10:28 AM
Barnsnelbon
Sep 27, 2015 03:07 AM
Bernhard
Sep 25, 2015 12:45 PM
black_thunder
Sep 22, 2015 07:59 PM
01ssls1
Sep 22, 2015 06:50 AM
