1987 Foreman 350 4x4 No Spark!
Old Jan 18, 2007 | 09:26 PM
HondaRider87's Avatar
Default 1987 Foreman 350 4x4 No Spark!
I've been trying to get my Foreman running, I bought it with the knowledge of it having no spark. I have since bought a new cdi and plug and am still not getting any spark! I tested a few wires leading into the CDI with a voltmeter, Some wires did nothing and some I got between 7 and 9 volts. When I kick it over, the fuel gauge lights up and the "OIL TEMP" lights up, but no spark!
I'm losing my mind!
Old Jan 18, 2007 | 09:47 PM
athlon450's Avatar
did you check all the fuses and the coil!
Old Jan 18, 2007 | 10:33 PM
I checked all the fuses on the back by the battery, But not the coil, I don't know where it is or how to test it.
Old Jan 18, 2007 | 11:12 PM
Would it be the Rectifier?
Old Jan 18, 2007 | 11:41 PM
OK, I get power to the CDI, but not to the coil. I tested the wires going into the coil and got nothing. So there is something wrong between the CDI and the coil. There are two wires coming out of another box that go into the coil, could that little box be the problem?
Old Jan 19, 2007 | 12:03 AM
athlon450's Avatar
Why are you kicking it? Use the electric start. The little box(rectifier) controls voltage going into the coil, that could be it.
Old Jan 19, 2007 | 12:07 AM
The starter motor burned up, it doesn't work anymore. What is that little box called that controls the voltage? Just to make sure we are on the same page, the little box i'm talking about is mounted on the front of the frame on the opposite side of the CDI box.
Old Jan 19, 2007 | 12:19 AM
athlon450's Avatar
CDI in on the front of frame on the left side(when sitting on machine). rectifier is on opposite side under the rear fender mounted on the frame. On the same side as the rectifier there should be a box that as all the connections! here is a diagram of the wiring for your machine! Look under the wiring harness section!
http://www.servicehonda.com/hard%20parts/atv/trx350d%20%2786-89%27/trx350_(d)_1986-1989.htm
Old Jan 19, 2007 | 12:41 AM
The part I was talking about is #28, but it says it's the Cooling fan control unit, but on my quad it has about 6 wires going into it and two coming out the go to the coil.
Old Jan 19, 2007 | 07:27 AM
HondaMechanic's Avatar
none
