HELP: Motor Idles but won't accelerate?
Old Jan 21, 2007 | 05:14 PM
Maxell's Avatar
Default HELP: Motor Idles but won't accelerate?
Hello,
I have a 2000 Honda Rancher TRX350. Was running fine, now it just idles...
When I give it gas it just stalls & wants to stop running. When I pull choke, it revs up ok, but when choke is not pulled
& I rev it up - motor stalls & wants to die.
Any suggestions appreciated.
Thanks,
Max
Old Jan 21, 2007 | 06:05 PM
athlon450's Avatar
Clogged main jet! My 86 350d had similar problem. the screws that hold the linkage to the plunger and needle in the card came out I took top off carb and reinstalled screws w/ locktite! just a suggestion!
Old Jan 21, 2007 | 09:53 PM
Maxell's Avatar
I am not sure I understand what you are saying?
Should I clean the carb with carberator cleaner?
Old Jan 21, 2007 | 11:13 PM
QWODER's Avatar
I'm pretty sure he means for you to take off the carb,turn it upside down,take the bowl that holds your fuel off the carb.When you get the bowl off there should be a main jet and pilot jet(jets are small objects that has very small holes in them that your fuel is sucked through),These jets should screw out.Take them out and see if they are clogged.If so then unclog them.Good luck.
Old Jan 21, 2007 | 11:24 PM
Maxell's Avatar
I took off the air cleaner & sprayed carb cleaner inside the carb, also took of 4 screews that held in a rubber diaphram & plastic peice that held a metal rod & sprayed carb cleaner there. Put back together & she started accelarting again.
Rode for about 1/2 hour without any problems....
I am not sure if that fixed it or not?
If not, I will take carb off & clean the jets like you suggested above.
Thanks Again!
Max
Old Jan 22, 2007 | 12:54 AM
hondabuster's Avatar
The handling you did, must have dislodged the obstruction. But because you didnt remove the float bowl and clean inside of it, the chunk of crud is still in there, waiting to plug it again. You can either do it now, or hope it doesnt decide to replug, at an inconvienent time, like on a steep hill, or deep puddle. Id clean it out now.
ghost civic
Jul 27, 2015 03:15 AM
Waddell4436
1) Engine problems..
Jul 20, 2015 09:46 AM
ghost civic
Jul 15, 2015 10:48 PM
ranvette
Jul 12, 2015 06:34 AM
J-Mack
Polaris Side by Sides
Jul 4, 2015 04:19 PM
