2001 honda rubicon will not start
Old Jan 23, 2007 | 10:30 PM
brakebush34's Avatar
Default 2001 honda rubicon will not start
I have a 2001 honda rubicon that will not start, it was running shut it off and then it would not start, Pulled the plug and there is no spark what should i start to look for?
Old Jan 24, 2007 | 12:33 AM
ForemanDan's Avatar
Have you had it long? Is the kill switch off on the left handlebar?
Old Jan 24, 2007 | 05:32 AM
No the kill switch is not off I even tested the wires and the switch to see if its bad it checked out good
Old Jan 27, 2007 | 09:03 PM
bear71665's Avatar
mines a different model but same thing it was cdi box
Old Jan 30, 2007 | 07:43 PM
are you talking about the coil if not where is the cdi box located?
Old Feb 2, 2007 | 02:14 PM
1988TRX250R's Avatar
Ther isn't a cdi box on a rubicon. It does have an ECM that controls everything form spark, shifting, fan motor, meter, etc. It is located on top of the storage box on pre-'05 models and in front of the steering stem on '05-up models.
If you have no spark, first try and replace the spark plug. Even plugs that look ok can be bad, I have seen it before. If that is not it, you will need to get a manual and a peak voltage meter (not a regular volt meter) to diagnose an no spark condition.
neilbedwell
Nov 10, 2018 11:02 AM
Jbird4681
Jun 9, 2015 01:59 AM
generalpops
Jun 5, 2015 08:23 PM
generalpops
Jun 3, 2015 08:25 PM
neilbedwell
May 31, 2015 11:11 AM
