2004 Raptor 660 - carb problem i think??
Old Jan 25, 2007 | 02:00 AM
ramman04's Avatar
Default 2004 Raptor 660 - carb problem i think??
Hi everyone...
I have a 2004 Yamaha Raptor 660 that I bought about a week and a half ago. I rode it for a few minutes before I bought it and it ran great. I rode it around the neighborhood once a couple of days ago and had no problems. Today when I went to go ride it started to give me problems. It cranked up just fine. It idled just fine. As I gave it gas, it started to spit / sputter. It would not really go anywhere and kind of jerked back and forth as I rode. I could give it full throttle and it would do the same thing. Even back fired several times. At first I thought that it was not warmed up yet so i let it idle and warm up, but that wasnt it. Like I said....it cranks and idles fine. I talked to a friend who said that there is probably just some trash in the carb.....he said mostly likely in the pilot jet. Sound right? Or could it be anything else?
Thanks
Dan
Old Jan 25, 2007 | 09:32 AM
hazardracing76's Avatar
Is your parking break set, most times that is the problem
Old Jan 25, 2007 | 09:41 AM
Speedy2222's Avatar
Is A Power Sport Junkie!
100% all the parking brake
Old Jan 25, 2007 | 09:53 AM
paintballbanshee's Avatar
DEFINITELY PARKING BRAKE
Old Jan 25, 2007 | 01:21 PM
ramman04's Avatar
Parking break????
It does this even when its in neutral. If its in neutral and I give it gas.....then it still runs really rough and back fires.
Old Jan 25, 2007 | 01:23 PM
ramman04's Avatar
Parking break?
It does this even when its in neutral. If its in neutral and I gas it, then it still runs rough and backfires.
Old Jan 25, 2007 | 04:37 PM
lucasislight's Avatar
get a parking brake blockoff plate for like 10 bucks, they come in all colors and look good, then take the PB cable right off and disconnect the wire/switch from the clutch perch. good luck!
Old Jan 28, 2007 | 11:47 AM
skramblr's Avatar
Parking brake has a switch that kills the power to the engine so you don't ride around with it on. Neutral, in gear, doesn't matter. Still keeps your engine from reving.
Old Jan 30, 2007 | 09:04 PM
fasterthanyou22's Avatar
Just push your parking brake all the way in so it touches the stop point so it is completely disengaged. You will then see exactly what the problem is. Then after that, you can wither bypass the sensor yourself, or get a block of plate. Block off plate looks cooler.
AtvManiac78
Jul 11, 2015 03:20 AM
generalpops
Jun 5, 2015 08:23 PM
generalpops
Jun 3, 2015 08:25 PM
kevbowe
Jun 1, 2015 01:17 AM
RaptorGuy01
Oct 31, 2000 04:23 AM
