Sport Quads Discussions on sport quads.
Octane Boost added to gas tank
Old Jan 25, 2007 | 05:17 AM
DrClaw's Avatar
Default Octane Boost added to gas tank
Opinions wanted on adding some Octane Boost to the quad gas?? If mixed properly does it do any harm to your machine??
I am already running 91 octane - VP racing fuel is a little costly..
Thanks
Old Jan 25, 2007 | 10:42 AM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
I run Klotz Octane Booster. What I like most about it is that it has an ester synthetic lube in it for the top end (kind of like the 2-stroke idea). It also has a fuel preservative (for long term storage) and moisture absorbers.
I'm not looking for a huge boost in octane, just a little over pump gas to insure that I never ever have detonation, so I use only a minimum amount. It will turn clear plastics a brown color, but I have had no problems with it making plastic brittle or eating through any rubber hoses, like some people say an analine based booster will do. My friends love the smell of my exhaust!
http://www.klotzlube.com/storeProdDetails.asp?pi=50
Old Jan 25, 2007 | 09:57 PM
ss97's Avatar
Lets Ride!
It's not a bad thing as long as it is worth it ...... If you have enough compression and are not wasting the extra octane it's OK .....
Recon pretty much summed it up for a lot of people. I know guys who run all kinds of fuel additives and they seem to have no problems. Of course you want to use a reasonable amount of product.....
I generally just run 93 pump, but my engine is totally stock. If I had mods I'd probably run a little extra octane too.
Old Jan 26, 2007 | 10:31 PM
Doctorturbo's Avatar
GOT BOOST!
Opinions wanted on adding some Octane Boost to the quad gas?? If mixed properly does it do any harm to your machine?? I am already running 91 octane - VP racing fuel is a little costly..
What issues are you having that you think you need octane booster? Whats the static compression? What does the factory call for with your quad?
Old Jan 27, 2007 | 04:11 PM
DrClaw's Avatar
The compression is the same as a basically a stock 450R.. I am not having any issues with it I just wanted a little more hp. I know 91 octane is not that impressive either.. For a race machine I just would have thought to add a little pep to the gasoline..
Old Jan 27, 2007 | 06:25 PM
GOT BOOST!
You will pick up nothing, none, nada, zero HP with plain octane booster. If you want more power your going to have to give it more O2. And the only way to do that (fuel wise) is with an oxygenated fuel.
If you want you can dump in about 10% methanol to your gasoline to pick up a "slight" increase in power. You might have to jet up accordingly.
Old Feb 4, 2007 | 06:17 PM
ACFreerider's Avatar
The only thing octane booster is good for is cleaning out your fuel system, besides it would only bump you from 91 to 92 oct. if you dumped a whole bottle in a gallon of gas.
wrencher82
Sep 30, 2015 04:27 AM
fredrikrosen
Sep 28, 2015 09:58 PM
2many2ride
Sep 27, 2015 04:35 AM
wrencher82
Sep 24, 2015 03:39 PM
WilliamBos
Sep 22, 2015 04:07 PM
