250r Tune-ups
Old Jan 26, 2007 | 07:32 PM
3W4L's Avatar
Default 250r Tune-ups
I was just wondering if you guys have any tips to get more out of a stock r without buying a big bore kit?
Old Jan 27, 2007 | 12:36 AM
carlw's Avatar
most 2 stroke mods do not envolve uping the cc's
250cc's can rip your arms out of there sockets.
Old Jan 27, 2007 | 03:46 PM
wrestleu's Avatar
More out of an R???? That one always baffles me...those things are plenty fast if you ask me. But if you really NEED more power, try a pipe and rejetting. That will give you the most bang for your buck.
Old Jan 28, 2007 | 06:14 AM
Saleenster's Avatar
Change your front sprocket to a 12 tooth, have your jug ported with new piston installed, bigger carb, new pipe, k&n filter and have it re-jetted. That thing will really be woken up. Then you will need a longer swing arm to keep the front end down. All that for about a grand. If you can, have it dyno tuned, this will net you a few more ponies
Old Jan 28, 2007 | 06:19 AM
Saleenster's Avatar
Both ESR and Paul Turner make great 250R pipes IMO. Most doubt, but I believe the Paul Turner high rev is the best all around ATC pipe for the 250R. I have rode quite a few different R's with diffrent types of pipes, the Fatty is the most popular, but very disappointing when switching to either and ESR or Paul Turner. Stock motor the Fatty does pretty decent, but a moded motor is where you see the difference.
Old Jan 29, 2007 | 09:57 PM
3W4L's Avatar
Thanks alot. If you have any more tips on 250r's just post them.
Thanks 3W4L
Old Jan 30, 2007 | 02:18 AM
JkAss's Avatar
Try Here
Old Feb 8, 2007 | 01:03 AM
wildcatkit52's Avatar
Buy a pipe.(ESR trx11 is what we run for dragging) Port CORRECTLY. Raise the compression and run 110 octane. Stroke it. Gear properly. Use proper size carb. Jet properly, dynojet if possible. 310 jugs aren't hard to find but just buying one from anybody is not a great idea. They could have improper port work for your application.
Alex Rodak
Sep 13, 2015 12:30 AM
Alex Rodak
Sep 12, 2015 09:39 AM
Alex Rodak
Sep 11, 2015 11:42 PM
Traci Carnahan Simmons
Aug 9, 2015 03:00 PM
CRamshaw777
Jul 18, 2015 05:46 PM
