Need Help with 1997 WoLVeRiNe
Old Jan 29, 2007 | 03:47 PM
GingerLove's Avatar
Default Need Help with 1997 WoLVeRiNe
I was riding today in the snow and it started to cut out. Now it cutts out at half throttle even when its not in gear .
What makes it do that ? how do I fix it ?
ANY HELP WOULD BE GREAT !
thanks. [img]i/expressions/face-icon-small-smile.gif[/img]
Old Jan 29, 2007 | 03:51 PM
Speedy2222's Avatar
Is A Power Sport Junkie!
might be water in your gas
Old Jan 29, 2007 | 04:07 PM
deanz400's Avatar
put it some place warm and dry for a couple of days and try it after that ,if still cutting out start checking all of your connectors ,die electric grease is a life saver .fill all connections and put back together
Old Jan 29, 2007 | 05:55 PM
GingerLove's Avatar
I was ridding for an hour before it starded actting up.
Even now it will run if I give it a little gas But from Half to Full throttle it just cuts out.
Old Jan 29, 2007 | 05:57 PM
GingerLove's Avatar
Pluss it gives a poping noise almost like a back fire [img]i/expressions/face-icon-small-sad.gif[/img]
Old Jan 29, 2007 | 11:12 PM
2FAST4URASS's Avatar
DIRTY CARB!!!!
Old Feb 2, 2007 | 10:21 AM
GlennJ's Avatar
Originally posted by: 2FAST4URASS
DIRTY CARB!!!!
Agreed. Pull the bowl and clean it out. Also check the main jet while you're in there.
Old Mar 12, 2007 | 04:52 PM
GingerLove's Avatar
I tryed to fix the carb. man was it dirty inside but
The carb sliped out of my hand and hit the side of the motor and broke this little plastic cover on the side.
It has a rubber cup on the inside of the cover that is broken off as well.
When I took it to the Yamaha dealer (all three) told me you cant buy the cover you have to BUY A NEW CARB $320.00 !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old Mar 13, 2007 | 02:55 PM
GlennJ's Avatar
Have you tried going to a parts site and seeing if you can get just the parts you need?
Ronnies has a good OEM parts section with diagrams. http://www.ronnies.com/
Old Mar 14, 2007 | 02:26 AM
GingerLove's Avatar
Ive been looking for days now but no luck. Im trying ronnies now thanx !
