How To Install Oil Cooler On Warrior?
Old Jan 29, 2007 | 11:22 PM
Raptor450's Avatar
Default How To Install Oil Cooler On Warrior?
Does anyone know how to install an oil cooler on a '97 Warrior? I have the Four Stroke Tech kit, and it has 2 brass elbow fittings, oil lines, and the coil. I know how to do everything except the brass fittings. I have seen a kit similar to this installed, and the fittings were screwed into the clutch cover. I dont really understand how oil will be pumped thru the coil, unless there is something I have to do internally. Some instructions would have been nice! Anybody have any ideas?
Old Jan 29, 2007 | 11:26 PM
Speedy2222's Avatar
Is A Power Sport Junkie!
u can do a big bear oil conversion
no drillnig required.. just gotta get the parts so u can put the adpater and other parts on.. then just ru nthe liens to the cooler..
just reread your post...
u have t odril lthe case in the precise spot.. there is a channel in the cover for oil flow.. that is what u are taping into.. so it will be preasurized oil flowing into the cooler
Old Jan 29, 2007 | 11:47 PM
Raptor450's Avatar
Thanks, Speedy. Makes a little more sense now. Do you have an oil cooler on yours or know somebody with 1, and if so did it do any good? When I ordered the stroker kit they recommended the oil cooler, so I figured it couldnt hurt to put one on.
Old Jan 30, 2007 | 03:37 PM
Speedy2222's Avatar
my buddy has one and it works good.. i am gonna do a big bear cooler setup on my warrior eventually if i sitl lhave it down the road
Old Mar 3, 2007 | 01:14 PM
Etodaj's Avatar
I have a oil cooler on my '93 warrior and it does wonder keepin the motor running smooth and cool.
Old Mar 3, 2007 | 01:54 PM
2FAST4URASS's Avatar
all this is from a diff fourm but the guy did a great job with all the info...
+ Document overview
+ Cooling anaylysis
+ Big Bear 95' items & needed parts
+ How to
+ Hayden cooler review
+ Quick Review of the tapped case design
+ Conclusion
- Document Overview:
Well I decided to make this kind of a short tutorial & review since many questions come about regarding this topic and the hardware for it. There is a cheaper method used to do this in which you tap the clutch cover into the galley but I believe this way is more safe and just better because this design compliments and goes along with Yamaha's original cooling systems for the Big Bear and other quads. This document will go over cooling systems usable on the Warrior and will also include a product review of a specific cooler (yes there will be pictures mmm).
- Cooling analysis:
As mentioned above there are two primary ways in use as of now implemented to run an oil cooling system on the warrior. To better explain how this works it helps to get down to how each system differentiates and compares. The first system im going to address is using 95' Yamaha Big bear direct bolt on parts to get the oil out of the case and up through our custom cooling system.
For comparison here is a Yamaha Warrior blue print diagram of the Oil management system. Take note to the areas on this 2D diagram since you will be using it to compare to a big bear blue print next.
Now... The next image is a 95' Big Bear blue print image; look how you can apply these cooling system parts in the red box to the warrior - a direct bolt on!!
You will need to buy pretty much all the parts in the above red box on the chart/blueprints. These prices are quoted from an online site, its cheaper do go through your local dealer (I paid $100.00 even for everything). Here is a list of the '95 Big Bear parts you will need:
1995 Big Bear parts list:
1. Plate, Adaptor (Reference #14) - $65.00 USD
2. Plug (Reference #15) - $1.50 USD
3. Spring, Compression (Reference #16) - $1.07 USD
4. Washer, (Reference #17) - $0.21 USD
5. Circlip, (Reference #18) - $0.42 USD
6. Cover, Oil Element (Reference #19) - $22.00 USD
7. 2x Joint (Reference #20) *OPTIONAL* - $13.00 USD
8. 2x Gasket (Reference #21) - $1.65 USD
9. 2x O-Ring (Reference #22) - $2.75 USD
10. Bolt, Hex socket head (Reference #23) - $1.79 USD
11. 2x Bolt (Reference #24) - $2.67 USD
Other Needed Parts:
1. A cooler (Hayden or Permacool) - $29.00 - $39.00
2. Teflon Tape - $1.25
3. 2x 3/8" x 1/4" Barbed hose adapters - $1.60 each (Home Depot plumbing section)
4. 10' of 3/8" Oil hose (1$ a foot) - $10.00
*Your cooling kit comes with hose clamps and mounting materials.
*This entire project will cost around $155.00 for brand new parts.
Here is how you will mod your element cover to accept the hoses for the cooler. Shown here are two barbed hose fittings (3/8" x 1/4") they can be purchased at your local Home Depot in the plumbing section for $1.60 each. Behind these fittings are the copper "gaskets" shown on the previous page charts/blue prints as Ref#21. Then finally the threads should be man handled with a good amount of Teflon tape for a nice seal. The barbs are then tightened down very snugly onto the copper gasket with a deep socket and socket wrench accordingly.
Below is a close up view of a barbed hose fitting.
Although not a picture of my quad here is how the parts are applied:
So just to recap you simply bolt the parts on over where the oil filter cap is, securely attach oil hose to the barbed fittings, & finally we run the hose up to the cooler and attach there - That is it!
- Hayden cooler review:
The cooler that I use is a Hayden part #401 Tranny oil cooler; this cooler fits PERFECT under the hood (5" wide 11" long) of the warrior and drops the temp of the oil up to 50*F!! This cooler also does not break the bank like some people would expect; you can buy this baby from AutoZone directly or their website for $29.00!!
Here are some images of the cooler and the packaging itself:
This cooler was a great buy, it is built strong, cools VERY well, and is light.
- Quick Review of the tapped case design:
MANY MANY people sell these kits and they are really not worth it. There are lots of mixed opinions about this method but they both have there pluses and minuses; here is a pic of this type of kit:
As you can see the cooler in this one is much smaller and you are required to drill into the oil galley through your clutch cover. While the other method may be more expensive if you mess up your clutch cover it will cost even more; I also think it?s a good idea to cool the quad with the design Yamaha intended.
- Conclusion:
Well here is the cooler that I use - A Hayden Part #401 Tranny Oil cooler. This cooler performs very well and I noticed a very big difference with this mod on the bike; you can tell its well needed cause the cooler will get very hot sometimes so you know it is helping. So keep your clutch and crank cool, extend your engine life, and retain HP by adding a cooling system to your Warrior. Instead of using the rubber oil hoses you could go steel braided lines and make it look even more cool guy X_X!
Old Mar 3, 2007 | 07:14 PM
Jasonp's Avatar
You can go to b l u e t r a x x .com or Yfm350.proboards31.com and find a lot of info there.
Old Mar 4, 2007 | 03:58 AM
Raptor450's Avatar
Thanks for all the replys. I went ahead and let the machine shop handle it, that way maybe it wont be f'ed up by me! Turns out you do tap into the oil channel in the clutch cover. (I didnt even know there was an oil channel). You put both 3/8" barbs in the channel and a ball bearing goes between them and acts as a check valve, that way the oil has to flow through the cooler. I have it all back in and together and it works! Now I just have to make a bracket for the coil.
Old Mar 4, 2007 | 03:01 PM
warpigs's Avatar
I did the clutch cover version, according to Mickey Dunlap of Four Stroke Tech, the clutch cover version routes the cooler oil directly to the crank first, meaning the crank bearings get cooled first prolonging their life. It was very easy to do, FST sells the kit for $95 and includes all the installation instuctions.
Old Mar 4, 2007 | 07:18 PM
Paulie1959's Avatar
warpigs can you email me the installation papers for the 4 strock tech oil cooler, paulcamino@comcast.net
Thanks paul
ReconBayou
Oct 31, 2022 05:37 PM
2many2ride
Sep 27, 2015 04:35 AM
Barnsnelbon
Sep 27, 2015 03:07 AM
Bernhard
Sep 25, 2015 12:45 PM
