New User - Clutch Question for 01' Scrambler 500 (Tried a Search Already)
Old Jan 30, 2007 | 11:15 AM
Blown97Cobra's Avatar
Default New User - Clutch Question for 01' Scrambler 500 (Tried a Search Already)
Hi guys!
I think I have what is considered a simple question(s). I picked up an 01 Scrambler last winter. I have changed the belt and done all the other necessary maintanence. Now, when out in the mud, I find myself at full throttle but the tires are hardly turning. After exiting the mud the clutch still slips until you really get going (similiar to when a clutch is slipping in a car) Since I've replaced the belt, I've ruled that out so now I'm turning to rebuilding/replacing the clutch. Here are my questions:
1) Do you agree that the clutch is toast?
2) What is a good, DIRECT replacement for the stock clutch. I'm not looking for anything earth-shattering. Just need a clutch that engages properly and I will be a happy camper.
Any advise is welcome!
THANKS!
Mike
Old Jan 30, 2007 | 11:54 AM
Kerbbirds's Avatar
Check out the secondary clutch first, there are three buttons in it that are probably worn and also check the spring to be sure it's not broken and in the right holes.
Old Jan 30, 2007 | 11:58 AM
excellent... sounds like a great place to start, thanks!. If I find that these are worn and are in need of replacement, what kind of job is it (time?, any specialty tools needed?), can I replace only those buttons?, or will I end up placing everything?
Old Jan 30, 2007 | 12:10 PM
Kerbbirds's Avatar
need a set of snap ring pliers, turn clutch upside down,push down on helix and remove snap ring, its got some pressure so be carefull, pay attention to what holes the spring is in so you can put it back, the clutch will come apart and you will see the buttons, takes a torks bit, cant remember the size, the buttons break because people jump and hit the ground with the wheels spinning. When you re-assemble,turn helix a third of a turn to get spring tension back , align splines and push down replace snap ring.This works better if you have someone to help.
Old Jan 31, 2007 | 12:46 AM
jta4455's Avatar
the clutch just doesn't slip, it sounds like after you hit the mud this happens, I would still check the buttons in driven and also check the bushings. also get a new seal for your pvt cover, sounds like when you hit the water it just runs in.
Cole Hadden
Jun 15, 2025 09:05 AM
maxjung
Jul 15, 2015 11:59 PM
coldnorthpol
Jul 14, 2015 11:22 PM
maxjung
Jul 13, 2015 05:11 PM
200es
Jul 10, 2015 09:09 AM
