backfire, popping
Old Jan 30, 2007 | 04:42 PM
Zab's Avatar
Zab
Default backfire, popping
I just purchased a used quad. When it is at operating temperature is runs great but when first started it pops and backfires untill it is completely warm is this normal? It has a FMF pipe and has supposedly been jetted for the pipe.
Old Jan 30, 2007 | 08:47 PM
DavidLT250S's Avatar
what kinda quad is it???
Old Jan 30, 2007 | 09:19 PM
Zab's Avatar
Zab
2002 400ex it was only about 15 degrees out when I bought it. The popping only happens when I give it gas when its cold.
Old Jan 31, 2007 | 02:36 PM
Coontis's Avatar
I have a 2000 400ex w/ a FMF pipe also. I have experienced the same type of problems in the cold weather. I was wondering the same question.... I'm guessing that it is normal and it isn't normal all at the same time, if that makes any sense? I am looking into getting a dial a jet kit when it gets a bit closer to spring and I think that may help alleviate any problems that I have been having w/ mine.
Old Jan 31, 2007 | 02:49 PM
hondabuster's Avatar
The popping and backfireing is symptoms of lean .
It may be just as simple as leaving the choke at partially open til it warms up, or bigger pilot jet, or opening up the mixture screw. Id start by opening the mixture screw, another 1/4 turn and see how much it helps.
Does the air box still have a sealing lid on it...or is it missing or have holes in it?
Old Jan 31, 2007 | 08:09 PM
v2rider's Avatar
I second the fuel/air mixture screw idea. Ive had to mess with mine for the same reason a couple times (when temps go from one extreme to the next)
ReconBayou
Oct 31, 2022 05:37 PM
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
Scooter's Shop
23
Oct 22, 2015 07:04 PM
Dunes and Dune Machines
Sep 29, 2015 09:35 AM
r1pilot83
Sep 27, 2015 07:38 PM
