2001 Rancher ES starting problem
Old Feb 1, 2007 | 11:15 AM
NAV165's Avatar
Default 2001 Rancher ES starting problem
I have a 2001 Rancher ES that will no longer start using the electric start. Intitially I developed an intermittent problem where occasionally it would only click when pressing the starter but if I pull started it, the next time the electric start would work. Now it appears the electric start will no longer work at all. It only clicks. I can still pull start it no problem, battery is fully charged. Any ideas?
Old Feb 2, 2007 | 01:49 PM
1988TRX250R's Avatar
Use a test light to verify you are getting power to starter post. If you are, remove the starter and disassemble it. Check the brushes and armature for wear. There's a good chance new brushes will return your starter to working condition.
Old Feb 2, 2007 | 06:35 PM
NAV165's Avatar
It was the brushes. Starts just fine now.
njrider64
Jul 4, 2017 01:40 AM
Big600twin
14
Jun 16, 2015 09:30 AM
Jbird4681
Jun 9, 2015 01:59 AM
generalpops
Jun 5, 2015 08:23 PM
generalpops
Jun 3, 2015 08:25 PM
