Sportsman hard start
Lately I've been having a problem with my 500 Sportsman. The first start of the day is brutal. I choke it, un choke it, throttle, no throttle, throttle wide open, etc. The starter will crank forever, but the quad won't start. I pulled the spark plug out to discover plenty of spark. I then hooked a booster up and wham! Immediate start. I rode all day with no problems starting until I put it on the trailer and got it home after about an hours travel time. Couldnt get it started to get it in the garage, had to push it uphill..whats that thing weigh anyway? Jeez...
try to start it w/ the pull cord. if it starts up w/ no problem then adqx2 may be right. was the plug wet when you pulled it out? is it getting gas, not enough ,too much? but if it started tight up w/ no problem then w/ the boost then chances are its form lack of volts. these are very spleeny when it comes to prpoer volts.
So let me get this straight...The starter will crank and crank and crank yet the quad isnt getting enough voltage? YOu think this may be a battery or a coil? Plenty of spark when I checked during the no start period, the plug was NOt unusually wet. I like the idea of the quad rechargind itself during the ride as we arent using headlights and such...You thnk the battery will hold enouhg charge to crank after a long period of time yet not have enough muscle to provide spark? Whats the procedure for checking the starter or the battery?
my 01 sp 500 always had a hard time starting in the cold of indiana and michigan, never couldn't get it started thow. i know this isn't an answer for your question but i was currious about your 589's, did you have to put he 2" lift on it go get thows on or woudl i be able to fit em with my stock ride hight. thanks hdnvn
bowz
bowz
food 4 thought-do you have a dynojet carb kit/procom hot ignition,the dyno's carb kit<i use 1,not my favorite kit>can make it hard to start<there's mixed opion's on that>now i really like my procom hot ignition box-it make's starting easier.D.R.W.
Get this....I tried starting my 500 again today with the same results. crank, crank crank and nothing. I Pull started as instructed and the second pull, fired right up. Good advice. I tried it several more times to confirm that it wasnt a fluke, fires up every time. Where to next I wonder...new starter? Do you think its a short between the starter and the battery? Let me know, this forum has pulled me out of another mystery!
